Home Forums Software Discussions Adobe Software how do i save an illustrator file into a hpgl file please?
  • how do i save an illustrator file into a hpgl file please?
    Posted by Neill Mennell on 20 February 2007 at 09:41
    hi guys.
    i use adobe illustrator cs2 to create shapes for my pacer.
    my problem is that i need to create some curves for a job but when saving to a dxf file it has to many vector points.and the curve it cuts is not smooth.
    i have downloaded a demo of signlab and saved the Ai file as a hpgl file, and this cleans all the vector points up . i wont be doing lots of these so didnt want to buy such an expensive piece of software
    is there a free piece of software that can save a Ai to hpgl.
    or could somebody do this for me . for a fee
    thanks
    Neill Mennell replied 18 years, 10 months ago 6 Members · 7 Replies
  • 7 Replies
  • Nick Minall
    20 February 2007 at 09:47
    I’m sure if you post the file some one will convert it for you
    Nick.
  • Neill Mennell
    20 February 2007 at 10:02
    thanks nick.
    but it involves about 10 files .upto now. and will be more
    and i really wanted to have a piece of software myself. trial and error thing
    untill you see it on the cnc you dont know if its right.
    20 February 2007 at 10:38
    Goto http://www.aidsoftware.co.uk and contact Jim there, the software there is not free but I know Jim also runs a Pacer and can give you ‘chapter and verse’ regarding getting your files to run properly.
    Alan D
  • Rod Young
    20 February 2007 at 16:09
    quote Neill Mennell:
    hi guys.
    thanks
    Hi Neill,
    I can understand your need to be practical about your expenditures, and I appreciate your frankness. For future reference, I will add the following comments that will perhaps help you to understand the SignLab product lines.
    For the work that you describe, you would need either the EngraveLab or ProfileLab product lines (which are industry-specific versions of SignLab). EngraveLab has a focus on parts marking, trophies, awards, etc., whereas ProfileLab provides production support for CNC machining. In particular, there is ProfileLab functionality that will automatically clean up the dxf file and apply tool paths. There is additional mapping support if you have organized your design with dxf batch files (this would be more for AutoCAD support). However, it is this general functionality that I suspect would streamline your production workflow.
    I can put you in contact with one of our routing experts to help broaden your understanding of the features that would be of specific benefit to you. Please send me a PM with a brief description of your setup, and contact information that I can pass along.
    All the best,
    Rod at CADlink
  • Justin Williams
    20 February 2007 at 19:17
    neill, we use flexisign to convert our AI files to HPGL (mod-edit)
    jus
  • Andrew Boyle
    20 February 2007 at 19:31
    We save ai files and export using this plug in……
    http://www.sharewareconnection.com/exdxf-pro2.htm
    using .dxf which we then cut on an old pacer.
  • Neill Mennell
    22 February 2007 at 09:24
    hi guys.
    thanks for all the advice.
    i am currently testing signlab , which the prospect to buying.#
    sometimes you just have to take the plunge.
    i will keep you informed.
    thanks again
    neill
