Home Forums Sign Making Discussions General Sign Topics how do i put a hanging strip glued onto vinyl correctly?
  • how do i put a hanging strip glued onto vinyl correctly?
    Posted by James Martin on 23 April 2008 at 21:48
    Hello
    Flood coated a piece of forrex today and am going to stick a hanging strip
    on tomorrow and was wondering if the hanging strip will be ok on top of the vinyl or should I strip a bit off and make it a forrex to forrex bond.
    I got the glue from Sign trade so its the right stuff.
    tks.
    James Martin replied 17 years, 8 months ago 4 Members · 8 Replies
  • 8 Replies
  • Karl Williams
    23 April 2008 at 21:58
    I would cut some vinyl away and glue direct to the foamex mate.
  • James Martin
    23 April 2008 at 22:06
    ye thought so.
    cheers.
  • Karl Williams
    23 April 2008 at 22:08
    Did you save any Chinese for me mate?
  • James Martin
    23 April 2008 at 23:00
    I had a Singapore noodles tonight.
    Just cant say no.
    I was between 10 and 10.5 stone from age 16 to 36 and then chinese food.
    Now its 12.5 up to 13. 😕
  • Karl Williams
    23 April 2008 at 23:05
    Enjoy it while yer can laddy! 😉
  • Craig Bond
    23 April 2008 at 23:29
    Definitely cut the vinyl away. Vinyl does come unstuck sometimes, and there goes the hanging strip 🙁 🙁
  • John Childs
    24 April 2008 at 11:07
    Cut vinyl away.
    I’d also want a positive mechanical fixing, so I’d put some small countersunk screws through it as well.
  • James Martin
    28 April 2008 at 20:25
    I was to late for screws that time but it was only 2000 by 50 mm high, 5 mm forex classic so not much weight on the glue.
    However, I’m building a larger affair with 5mm gloss ability board and it’s two, almost full size boards side by side, so I will definitely put a few fasteners through the hanging strip as the gloss is a fair bit heavier.
    tks.
