Home Forums Sign Making Discussions Graphic Design Help how do i put a hairline around an image for a contour cut?
  • how do i put a hairline around an image for a contour cut?
    Posted by Steve Radford on 22 August 2006 at 16:58
    Been trying a few things with our new VersaCAMM and I have a need to incorporate a white calalily flower on a black van.
    I’ve opened the image in Photoshop, cut it out and saved it.
    I then import it into CorelDRAW as I now need to place a hairline around the image for cutting, but without manually drawing around it with the pen, I can’t seem to find a simple solution.
    I’ve even imported the Photoshop PSD file and now have it as a floating image without a white background but I can’t just have a simple line around the outside?
    CorelTRACE makes a mess of the whole thing. I’m sure I’m missing a trick here. Is there a simple solution to placing a CutContour line around an image ready for print & cut?
    Steve Radford replied 19 years, 4 months ago 5 Members · 7 Replies
  • 7 Replies
    22 August 2006 at 17:49
    there are shorter cuts for some things but learn to digitise and you would have done it quicker than putting it on here.
  • Steve Radford
    22 August 2006 at 18:29
    I’ve just traced it using the Bezier tool and it took me 12 minutes, and with practice I can see it coming down to at least 5 minutes, maybe less.
    It’s very frustrating when you have such cool tools as the magic wand and magnet tool in Photoshop and these things take 2 seconds to do!
    I wanted to make sure I wasn’t wasting away my time tracing it by hand if a simple click of the mouse using a tool in CorelDRAW would do the trick.
  • Steve Curry
    22 August 2006 at 18:43
    If you have cut it out in photoshop and have it on a transparent background, go to help at the top and you should see export transparent image, follow the wizard and this will save an eps file with a vector trace around the outside. It normally needs simplifying in a vector package afterwards but its a starting point.
  • Steve Radford
    23 August 2006 at 07:51
    Brilliant, thanks, that’s what I was looking for, why it’s buried under the help menu as appose to the file menu is beyond me, but we got there in the end…well almost!
    It now has a trace outline around the outside, however I can’t seem to select and change this to a CutContour line in CorelDRAW? I have my CutContour setup in my palet and have used it with success on other stuff. I just can’t seem to select and change the hairline colour whatsoever?
    Any ideas???
  • Ramj
    23 August 2006 at 11:38
    Is the shape layer locked?
    the shape will just be filled… so maybe its something to do with applying a stroke in corel?
    I found with importing anything from an adobe product into corel I had a host of different little difficulties
    Also, if you did need to specify a path that isn’t just the transparent background, you can use the vector tools in photoshop, including using the magic wand, right clicking and selecting convert selection to work path, and then open it up in illustrator(if you have it) and use that as a cut path,
    P.s, not really of use to you personally
    I personally use the vector tools in photoshop when using quark, as it can automatically detect the vector path and wrap text around,
    29 August 2006 at 20:53
    is this what you’re tryig to do ?
    pen tool and shape tool took about 5 mins tops,
    i dont do print so forgive me if i’m wrong 😮
  • Steve Radford
    30 August 2006 at 06:43
    Thanks. I too hand traced it as I mentioned above, I was just looking for an automated way of doing this, without wasting 5 minutes everytime I need a CutContour outline.
