Home Forums Software Discussions Corel Software how do I print off pantone chart??
  • how do I print off pantone chart??
    Posted by Nick Minnery on 16 April 2014 at 14:34
    Hi guys
    Could somebody tell me how to print off a Pantone colour chart please?
    As you know, Pantone colour never look as they should when digi printed, so I’d like to print them all off, so I can then choose these closest one to my Pantone book/swatch.
    Thanks 😉
    Gert du Preez replied 11 years, 8 months ago 4 Members · 9 Replies
  • 9 Replies
  • Jon Marshall
    16 April 2014 at 14:36
    Might be a chart included with your RIP software
  • Glenn Sharp
    16 April 2014 at 14:42
    we use this one Nick
    The pantone chips are on the right with their CMYK equivalents on the left
  • Nick Minnery
    16 April 2014 at 15:16
    Cheers Jon, where would it be in the Roland RIP software? I looked under ‘media’, there’s nothing there.
    Thanks for the download Glenn. So, if I imported that chart straight into my Roland RIP software, and printed it- those pantone colours would look exactly the same as the Pantone colours I select and export in CorelDraw? Sorry if sounding a bit thick.
  • Glenn Sharp
    16 April 2014 at 15:33
    Nick,
    Import that PDF into corel and and send it through to yor RIP from there
    with our setup exporting into the rip as a PDF will give different results to exporting it as an EPS
    once you have your printed chart/charts use them as a reference to match to an actual Pantone reference. You migh tfind that actual Pantone 300 is 301 on your new chart…or it might be that the CMYK chip (left hand side) is closer than the pantone (right side)
    Once you import that chart into corel and click on the individual chips you’ll see what I mean
  • Jon Marshall
    16 April 2014 at 16:01
    you might want to print one for each of the main medias/profiles you use too
  • Nick Minnery
    16 April 2014 at 16:16
    Big help Glenn, thank you very much 😉
    Thank you to Jon too!
  • Gert du Preez
    17 April 2014 at 12:31
    Ive been using a colour chart I made up with ALL the pantone colours in the Corel Library for the past few years. There is 1144 colours on that ‘un……
    Printed on Vinyl, PVC, Reflective and Photo Paper. Use that to find the colour, open the Corel file of the colour chart, copy the relevant colours, paste into the Corel file Im working with, and copy properties from my swatch coulour.
    Sounds long winded, but actually only take a few seconds!
  • Nick Minnery
    17 April 2014 at 13:10
    quote Gert du Preez:
    hanks Gert! When you say ‘open the corel file’, how do you copy the properties?
  • Gert du Preez
    17 April 2014 at 16:21
    Nick,
    Select the item you want to copy the fill to, then click on "Edit" – from the drop down menu select "Copy properties from…." – that will open a new menu with check-boxes for Outline Pen, Outline Colour, Fill, and Text. Just check the box "Colour" and then click on the object you want to copy the colour from.
