Home Forums Software Discussions Adobe Software how do i make this illustrator file a cuttable one please?
  • how do i make this illustrator file a cuttable one please?
    Posted by Derek Hunter on 6 December 2005 at 21:07
    Ok guys i seem to have mastered the pen tool in illustrator and can manage to create a vector mask but i run into a problem, how do i make this into a cut file? i tryed saving it as an .EPS (im useing vinyl master pro) but it will not even show the picture once converted. what am i doing wrong guys please help 😥
    Lynn Normington replied 20 years ago 6 Members · 27 Replies
  • 27 Replies
  • Andrew Boyle
    6 December 2005 at 21:25
    are you creating a clipping mask for an image then trying to us this clipping path to cut the image?
    RFC in Champions League :funky2:
  • Nancy Wannous
    6 December 2005 at 21:38
    Hi Andrew I’m trying to email you a screen shot but in the forum there is no option to add attachment. I use Illustrator everyday and i though if i take screen shot that could help you manage. 🙂
    Nancy
  • Derek Hunter
    6 December 2005 at 21:46
    ok im drawing round the image with the pen tool, i then click new layer and then i right click on the bit that i have gone round with the pen tool and click create vector image. then i save it as a eps but then i can view it in VMP
  • Nancy Wannous
    6 December 2005 at 21:52
    If you want to create a cutting path you need to do it in illustrator.
    Double click on the swatches palette then follow the steps there.
    Name you color swatch so the color rip will pick it up as a cutting path.
    choose Color type as spot color. And that should give you an idea.
    Nancy
  • Derek Hunter
    6 December 2005 at 22:04
    OK IM SO SORRY !!! i was useing photoshop 😳 not illustrator i was busy in photoshop whilst i was posting.
    wannousnancy
    is it possible you could give me a quick step by step how to create a vector mask/image in illustrator?
    Im so sorry guys (!)
  • Nancy Wannous
    6 December 2005 at 22:09
    Look I have an idea how about you email me the file and ill do it for you wont take me too long. you just let me know what you want done and what file format do you want it as.
    I can tell you how to do it but its toooooo long.
    (mod-edit)
    Nancy
  • Derek Hunter
    6 December 2005 at 22:12
    Nancy
    I dont have a image to hand im only just trying to learn about illustrator thats all thanks for the kind offer also sorry if i wasted your time. 🙁
  • Nancy Wannous
    6 December 2005 at 22:20
    ok ill give it a shot.
    Illustrator you have your tool palette on the left side ok
    There is a PEN TOOL choose that with this tool you can draw anything you want . its tricky. lots of practice.
    Then its simple its like everything you draw is vector unless you rasterize it ten it will become a flat image. you can save PDF format .ai .eps etc.
    It a very good software much better then corel draw. if you need any help let me know. your not waisting my time. 🙂
    6 December 2005 at 22:22
    quote Derek Hunter:
    hi derek 😀
    please dont be “sorry” on thinking your wasting peoples time on the boards…this is what we are all here for, and we all love helping folk out 😀 isnt that right members? 😉
  • Derek Hunter
    6 December 2005 at 22:23
    Thanks Nancy
    When i draw round a image say… a circle for example. a get half way round it seems to be getting covered by another layer or something in white is this right?
  • Derek Hunter
    6 December 2005 at 22:24
    Thanks Nicola/Members 😉
  • Nancy Wannous
    6 December 2005 at 22:26
    that means your fill is set as white color you can change that in your tools palette on the left side see these squares there is a fill and there is a stroke. You can change there colors. either from the swatches palette or double click on them. 🙂
  • Nancy Wannous
    6 December 2005 at 22:29
    that’s right Nick one day i will need help myself trust me on that. 🙂
  • Derek Hunter
    6 December 2005 at 22:30
    so is it supposed to fill or is it got to be set to stroke so it dont fill?
  • Nancy Wannous
    6 December 2005 at 22:36
    depends how you want your drawing to look
    Fill stands for inside color and stroke stands for edge color
    if you don’t want any color there on the stroke and the fill then you got to select each one and choose the little white square with red slash right below the big squares.
    Nancy
  • Derek Hunter
    6 December 2005 at 22:46
    ok drawn round the image do i just save it as a eps and then its a cutfile?
  • Martin Grimmer
    6 December 2005 at 22:49
    Derek,
    Not sure if same for vinyl master pro – but in Flexi you will need to save the Illustrator file (or EPS) as Illustrator version 3 – not CS. Give this a try.
    Martin
  • Nancy Wannous
    6 December 2005 at 22:55
    ok now you have your drawing ready ok
    the next step is to make that path separate from others as a cutting path
    lets see
    you know the printer you use the cutting path what does it have to be named so the color rip software of your plotter picks it up.
    for example for my printer i use Roland and it requires for me to save the color from my swatches of the cutting path and name it as CUTCONTOUR. so when i open my eps file in the color rip software it will pick up the CUTCONTOUR as cutting path.
  • Derek Hunter
    6 December 2005 at 22:58
    oh i really dont know that one, im useing a Master XY380P cutter/plotter
  • Nancy Wannous
    6 December 2005 at 23:14
    did it come with a manual
    can you look it up in the book and let me know.
    Nancy
    6 December 2005 at 23:19
    quote wannousnancy:
    i thought you had to be spot-on with the layout of the word….CutContour (?)
  • Nancy Wannous
    6 December 2005 at 23:21
    yeah but i made it CAPS for him to see it lol
    its CutContour
    6 December 2005 at 23:22
    quote wannousnancy:
    its CutContour
    😳 😳 sorry me being a smart @rsE 😉
  • Nancy Wannous
    6 December 2005 at 23:25
    That’s ok Nik
    I didn’t take it as ur being a smart S 🙂
    lol
    So what printer do u use?
    6 December 2005 at 23:33
    quote wannousnancy:
    i have a cadet, not had it long about 7 weeks….but i love it 😀
    funnily enough, i can only get my “CutContours” when using illustrator 🙄 the only programme…..i cannot use 😕 but im getting there slowwwwwwly 😉 (signlab is my fave) 😉
  • Nancy Wannous
    6 December 2005 at 23:38
    I c
    If you need help in Illustrator let me know that’s my personal email address (mod-edit)
    To be honest its very good software i use corel photoshop indesign quarkXpress corel trace photo paint and more can’t remember them .
    and dream weaver image ready bit of flash and java.
    Nancy
    7 December 2005 at 07:55
    quote Nicola McIntosh:
    quote wannousnancy:
    Nik Why cant you contourcut from sign lab? or did I read that wrong
