Home Forums Software Discussions Corel Software How do i make corel colour in text please?
  • How do i make corel colour in text please?
    Posted by Martin.G on 14 June 2008 at 18:06
    I have a roland cutter/plotter, and want to do some lettering with a pen. i can get the outline, but cant get it to colour the letters in.
    would anyone know how i do this please?
    ive tried using fill, but that didnt work.
    i have coreldraw8
    thanks in advance for any help
    Alan Drury replied 17 years, 6 months ago 12 Members · 17 Replies
  • 17 Replies
    14 June 2008 at 18:14
    I doubt if you will get a solid fill,
    I know its possible to a certain extent in signlab (well it used to be) the pen did a cross hatch pattern, if using paper.
    I think you could do similar with corel, but you would need the fill to be a vector, so maybe do a fine cross hatch design, and clip into the shape,
  • Martin.G
    14 June 2008 at 18:24
    I thought that too peter,, but if i try that, then even in wireframe, the pattern does not show, so doesnt ask the cutter to draw it.
    14 June 2008 at 18:33
    What I meant was, the fill has to be lines, so the plotter just draws many or a continuas one to shade the shape, why do you need to fill on a pen drawing?
  • Martin.G
    14 June 2008 at 18:36
    im trying to make a "just married" sign for the rear window of a car, and wanted it filled so easier to see.
  • Glenn Sharp
    14 June 2008 at 18:37
    It’ll be a bit long winded but you could create a series of cross hatched lines at whatever distance apart you wanted (so you have a rectangle shape of cross hatched lines) with the line tool and then combine those lines………make those series of lines bigger in area than your largest letter…….duplicate the lines for every letter and then trim the combined lines to the letter so each letter will be filled with the cross hatched shape
    clear as mud
    I can’t think of anyway you would get a solid fill on the letters though…..other than cut them in vinyl and leave them on the backing paper
    14 June 2008 at 18:41
    just print on your desk top printer then, Cant understand why you want to complicate matters? 😉
  • Martin.G
    14 June 2008 at 18:43
    quote Peter Normington:
    its all about learning i guess.
    id like to learn how i can do it.
    cheers for the tips though i will let you know if i get it
  • Graeme Harrold
    14 June 2008 at 19:28
    Create a series of cross hatched lines and group, drop desired text on top as an outline. Select both and select "Trim" and delete the extra hatching, Job done…..
  • David Rogers
    You have a Roland plotter….cut your text in vinyl and be done with it… 😉 even if you end up sticking the vinyl to a length of paper!
    Pen plotting with an infill is slow, laborious & never looks all that good. To get good enough colour density the paper will be saturated & potentially rip…or you’ll run out of ink in the pen!
  • Ian Johnston
    14 June 2008 at 20:04
    quote David Rogers:
    :yes1: :yes1: :yes1:
  • Ian Bingham
    14 June 2008 at 20:38
    if you really have to do it with a pen, use contour and check to centre then use .5mm spacing
    but agree with others, waist of time
    Ian
  • Steve Underhill
    14 June 2008 at 22:35
    cut it from vinyl and leave it on the backing paper.
    rather than stick it to a length of paper.
    :lol1:
    14 June 2008 at 22:39
    steves probably the quickest.
    by the way the old hp pen drivers used to have a fill command, possibly well in to the honeymoon before it finishes,
    15 June 2008 at 02:55
    then you’ll want to pray it doesn’t rain on the day!
    agree with others, waste of time though
  • Steve Underhill
    15 June 2008 at 08:45
    Unless its raining inside the car why would it matter?
    its for the rear window.
  • Bill McMurtry
    15 June 2008 at 10:17
    Just plot the outlines and hand colour the lettering with wax crayons, that way any rain inside or outside the car won’t be a problem 😀
    16 June 2008 at 07:39
    If you want your plotter to fill in with a pen I think Ian’s solution with a contour is probably as good as any.
    Alan D
