Home Forums Software Discussions General Software Topics how do I make centres of letters ‘see-through’ for printing?
  • how do I make centres of letters ‘see-through’ for printing?
    Posted by Lorraine Clinch on 31 October 2005 at 12:54
    how I can make the centres of letters ‘see-through’, for printing? I have a 3-colour logo, which I have always cut in vinyl, but want to print this time.
    The logo has 2 colours running across it, both of which can be seen behind the letter centres, but I can’t get my head round it (using Signlab).
    I’d be very grateful for some help,
    Many thanks
    Lorraine
    Lorraine Clinch replied 20 years, 1 month ago 8 Members · 12 Replies
  • 12 Replies
    31 October 2005 at 12:58
    can you ungroup it all? then change the circle to the correct colour 😀
  • Peter Shaw
    31 October 2005 at 13:01
    Don’t understand.
    The centre of an O or an e is see through. Or do you mean transparent letters?
  • Dave Bruce
    31 October 2005 at 13:07
    Select text click invisible colour(bottom left swatch) then pen icon select outline, choose colour hey presto.
    Hope that helps
  • Lorraine Clinch
    31 October 2005 at 13:30
    Hi, I’m obviously not being clear (there’s a pun there, somewhere 🙄 )
    I’ve attatched a jpeg, to demonstrate. At the moment, I can only colour the letter centres one colour, and I need them to be “not there”, as if I’d laid cut vinyl over the top of the two blues-only printed, not cut. Then I could see both blues thru’ centres.
    Still clear as mud?
    Edit: Can’t attatch here- will find somewhere I can!
  • Nick Minall
    31 October 2005 at 13:49
    You mean when you look at an O say in filled mode you just see a solid circle?
    I don’t use signlab but in Omega you have to combined them so the center is then clear.
    Hope that helps!
  • Jayne Marsh
    31 October 2005 at 13:54
    Not sure how signlab works, but you need to combine the centres with the outside vector so that the two items become one object. In Flexi its called compound, in illustrator its also called compound. It could be called make path or combine or something similar. Either way all you are doing is making two objects into one so the centre becomes a hole. I am so rubbish at explaining sorry 😳
  • Frank Droog
    31 October 2005 at 14:35
    It sounds like your letters are graphics and not text.
    If the inside and outside of your letters are sererate objects, the select all your text and then click on Arrange/Make Path
    This should make only the insides of your text fill with the fill color.
    You will then be able to see the objects underneath in the insides of the letters.
    This is actually the same thing that Nick and Jayne mentioned above.
    We call it Make Path, others call it Combine
    frank at cadlink
  • Lorraine Clinch
    31 October 2005 at 15:11
    Frank,
    You and Jayne were right, I was selecting only one letter, and it wouldnt allow me to ‘make path. Selected all, and it’s done it. Thanks so much.
    Power of the boards yet again!
  • Dave Bruce
    31 October 2005 at 15:26
    Ar now I see so the text wasn’t text it was graphics, I thought that Lorraine had been cutting this in vinyl, so how can she cut it if the centres were not ‘taken out’ of the outer path?
    Anyway solved so I can get back to work now.
  • Stephen Morriss
    31 October 2005 at 15:34
    Dave Said
    “how can she cut it if the centres were not ‘taken out’ of the outer path?”
    Cos the cutter isn’t bothered about the two parts of the letter being combined, it just cut two line and then you weed out the inside one.
  • Dave Bruce
    31 October 2005 at 15:41
    Ofcourse Stephen, but you don’t see the proper layout on the screen, you can’t work like that surely.
  • Lorraine Clinch
    Strange how only one woman can confuse so many men!!! :lol1: :lol1:
    Dave, you can see the layout and how it’s going to cut.
