Home › Forums › Sign Making Discussions › Neon, LED, Lighting › how do I make a neat corner on a sign tray please?
Posted by Tim Cockings on 29 July 2009 at 13:24Can anyone please give me advice on how to produce a neat corner when producing sign trays from dibond?
Tim Cockings replied 16 years, 4 months ago 4 Members · 4 Replies -
Tim, I’m pretty sure there is a Tutorial on producing sign trays, should have all the info you need.
General advice, and one way of making a corner
http://www.uksignboards.com/viewtopic.p … ond+manual
Jusr noticced, Its been downloaded 299 times!!
Personally I just continue the routed lines and cut out the "square" in the corner, and then glue in a foamex block to hold the corner firm
quote Peter Normington:General advice, and one way of making a corner
Personally I just continue the routed lines and cut out the “square” in the corner, and then glue in a foamex block to hold the corner firm
I do the square out of the corners too. Much neater than a flap hacked into an adjacent side.
Little bit of 1"x1" alu angle in the corners – option to just use adhesive (Evostik serious stuff) – same that i run in the channel before folding over, or to rivet. Very rare that I rivet them.
Thanks Guys
I have searched high and low for the tutorial. Thanks for the link.
We practiced the folded corner method but just can’t get a tight enough bend on the flap to make it look half decent.
Cutting out the square in the corner and gluing in behind it seems the preferred solution.
Tim
