Home › Forums › Sign Making Discussions › Vinyl › How do I laminate motocross vinyl graphics?
Posted by Damian Blackburn on 27 February 2012 at 21:11Hi, in the next month I will be getting a Roland sp300 and I wanted to make some graphics for my motocross bike. Once the graphic is printed to vinyl how do you cut the laminate to shape? Or do you cut laminate and graphic all at once? Thanks
Damian Blackburn replied 13 years, 8 months ago 3 Members · 11 Replies -
Yes, print the vinyl and allow to gas off (24hrs), then laminate and then cut.
I’ve not done motor X stickers, I’ve read that some machines struggle to cut thicker material often used for motor x stickers.
How does it know where the graphic is? Does it print reg marks to read?
Depends on your set up ie: software, hardware as to exactly how you do it.
But yes print the appropriate registration marks, so the cutter can identify where it is in relation to the print.
I have the same printer and also do my sons motocross bike. 2 things use the correct materials and second full heat and full blade pressure to cut the thick lamination film
Rich 😀 -
Yes mate, graphics are still looking great and its been a while, check out Allprints new lam and film which is great.
Best to give the suppliers a call, not really allowed to post things like cost as we are all on different discounts
thanks Rich -
Print one
Hexis do a type which I have good results with
and All print supplies
thanks Rich -
Thanks for all you help!!!!! That cleared things up.
