Home Forums Printing Discussions General Printing Topics How do I know if I need to change my printheads?
  • How do I know if I need to change my printheads?
    Posted by Canadaguy on 27 July 2006 at 14:05
    I have a mimaki JV2 and for some reason, when I print, the colors are bleeding into each other? I printed a file that i had previously done with no problems and now the problem occurs?
    It seems that too much ink is being laid down and are mixing before it has a chance to dry?
    Any ideas?
    David Rowland replied 19 years, 5 months ago 4 Members · 5 Replies
  • Mindaugas
    30 July 2006 at 21:01
    hi
    first try clean print head,
    i did have smiler problem, whit Roland,
    30 July 2006 at 23:11
    Have you inadvertantly changed to a different print profile? These make all the difference to your printers output. Check that you are still using the same profile as before this problem occured.
    31 July 2006 at 00:37
    first thing I think of is heat in the plattern… second is surface of print… third is too much ink coming out of heads (ink limits)
    are you new to a JV2?
    JV3 User
  • Canadaguy
    31 July 2006 at 00:44
    i figured it out…
    the setting on the machine was on 360dpi extended… i had been running 360dpi previously…
    thanks for everyones help!
    tho this process was a little stressful, it has provided me with an alternative way to produce my prdts with better colors…. so all in all, the trouble was worth it!
    quote :
    pretty new… i have had the machine for 1 yr, but since i don’t really change settings and profiles, i never explored the various functions…
    if you know of any tendencies and habits of mimaki’s, i would definitely like to hear them…
    thanks again!
    31 July 2006 at 01:02
    there plenty of habbits with mimaki’s… damn good printers though :lol1:
