Home › Forums › Software Discussions › Adobe Software › how do i import illustrator files into signlab please?
Posted by Dave Bruce on 19 August 2005 at 16:41I have a customer just learing Illustrator, she can’t afford to pay my high prices for design so wants to do the designs (for etching resists) so that I can open in Signlab then cut. At the moment when I import her file in to Signlab I get a double line to cut and I have to delete the inner line to get the correct result.
I don’t use illustrator so anybody tell me how she can draw objects that I can then import without further work.
Much appreciated.
Gordon Forbes replied 20 years, 4 months ago 8 Members · 15 Replies -
Sounds like she needs to outline her strokes. This depends on how complex the design is but try this – select the object/s and goto the OBJECT menu select PATH then OUTLINE STROKE. Hope this helps.
I have had this problem from corel into signlab. If strokes AND fills are applied you get a double line.
That’s how Illustrator works, some artwork is impossible to convert for cutting. Strokes all over the place. I’ve had to resort to converting to bitmap and retracing.
illustrator is good for getting files ready for cutting……
need to check artwork:
Type – Create Outlines
Object – Path – Outline Stroke [this the point double strokes may appear when working with text etc]
View – Outline for final check and save as ill3 or 5.5
[use pathfinder to weld certain items like you would do in FlexiSign]
should be fine
Andrew
Dave.
I do a lot of work on the import filters in Signlab.
Can you email me a (simple) sample file that has this double line.
I mean , send me the Ai or Eps file, not your cdl file.
I may be able to add some code to eliminate it automatically.
I could then email back a new import filter.I am trying to add some code to make importing of AI/EPS/PDF work for people who want to print or cut.
Cutting people dont want thick lines while printing people do.There is a chance there is allready a Hidden INI file setting that does what you want. I added this for a special customer and its OFF by default.
If you are comfortable editing INI files,
1: close signlab
2: find and edit signlab7.ini with NotePad (or signlab6.ini)
3: search for [IMPEPS] <– including the brackets
4: add new line just below called AllwaysHairline=1eg.
[ImpEps]
AllwaysHairline=1frank
(mod-edit)
Thanks guys the customer is going to try your ideas.
Frank I would if I had your Email.
sorry. forgot.
(mod-edit)
Sorry again.
I didnt read rule 7 about email addresses.
And i dont seem to have permission to reply via PM. -
Here you go Frank
(mod-edit) Please read board rules :police: admin@uksignboards.com please use the pm system which you have access to, not the public forum for posting contact details.
You usually just weld when you import to signlab to get rid of the double outline tells you this in signlab somewhere I think.
Yer I tried that, didn’t work in this case.
Thanks anyway
Just a quick tip Frank, people who have UKSG access to this board can access your website and email you direct. If you have filled in your “profile” correctly (see button at top), the UKSG members could contact you at their descretion.
Thanks Dave R. I think i updated my profile as you sugested.
The AI files in question where created in Illustrator 10. They consist of objects with NO fill and everything has a 1 point outline according to the menu items in Adobe. But for some reason, they dont export as thick lines. Instead they export as a filled series of curves that describe the outline of the thick line. Looks like a bunch of neon tubes.
I cant find how to force Adobe 10 to export thick lines.
Tried saving as earlier version but same result.
If i do the same in Adobe 7, it does export as thick lines.The only thing that does work is to Select All in Adobe, give everything 0 width and give it a fill color. Doing this also shows that few if any of the paths are connected properly.
I will keep diging on how to export Thick lines with Adobe 10.
Really baffeling.
Corel 12 also imports the files with this tube shape of objects.frank
Ok we are making headway I think. Customer needs to know how to Xoweld in Illustrator, in other words remove something from the background.
Donno if I am reading this right but in illustrator use the pathfinder and highlight the shape in th larger shape highlight both then choose exclude overlapping shapes.
If thats what you want but i’m not sure.
Goop
