Home › Forums › Printing Discussions › Uniform Printers › how do i get into the service menu on the cadet please?
Posted by Paul Jamieson on 9 January 2007 at 19:17Hi all,
Does anyone know how to get into the service menu on the Cadet? I have the service manual for the SP300, but when I use the info from this to get into the menu it says, Service menu is protected.
PaulPaul Jamieson replied 18 years, 11 months ago 5 Members · 8 Replies -
hi
the entry sequence changed with the later firmwear speak to your supplier.chris
Press the arrow keys: down – right – left – up
and then press AND HOLD: right – down – left and then the power switch.
This puts you in service mode then press menu for the options.
Thanks guys….The service manual said to hold the left-right and down buttons while powering it up from the power button, like you said Dave. Although it said nothing about pressing the 4 arrow keys before doing this, I’ll give it a go in the morning.
I’m guessing I have the later firmware version though, as suggested by Chris 😕Looks like a phone call!
Thanks again -
An I was told it had to be done in 10 seconds from the start.
Watch what you are doing as you can kill the machine if you change some of the power settings by mistake.
Goop
I tried them and just got the message "service mode is protected" mine shows V1.2 when it starts up but I don’t know if that’s the machine or the firmware.
I checked my firmware today and it’s version 2.0. I should have known really, as it tells you as soon as you turn it on 🙄 I’ll make that call tomorrow and let you know what happens.
Paul
