Home Forums Sign Making Discussions General Sign Topics how do i fix aluminium frames properly please?
  • how do i fix aluminium frames properly please?
    Posted by Warren Beard on 15 January 2008 at 18:24
    Hi All
    Just want to confirm something as I have not done one before. I’m fixing a panatrim frame to a unit with self tapping screws,
    do I;
    A) drill a pilot hole through the frame and wall panel about 1mm just to guide it in.
    or
    B) drill a pilot hole in the frame only larger than the screw so that it grabs and pulls the frame against the wall panel.
    or please let me know the best way to secure the frame to the wall panels.
    Warren
    Peter Normington replied 17 years, 11 months ago 4 Members · 11 Replies
  • 11 Replies
    15 January 2008 at 18:34
    with self tappers, pre-drill clearance ‘oles in the frame, offer up to the unit and mark a few out to hold in place, then drill pilot holes in the cladding. drill the rest of the pilot holes once the frame has a couple of screws holding it.
  • Warren Beard
    15 January 2008 at 18:44
    Cheers Peter
    I really appreciate the way you are almost always the first person to respond to my posts with excellent insightful help.
    I hope I can somehow one day repay you for all the help you have given me.
    Warren
    15 January 2008 at 18:54
    Just a pint at sign uk will be fine 😀
  • Warren Beard
    15 January 2008 at 19:08
    That’s the least I could do 😉
  • DaneRead
    16 January 2008 at 07:19
    have you used those self drilling screws. Its got a type of drill bit head on the end they use it for roofing. You wont need to drill a hole in the ally it will drill it for you and then go into the cladding behind. its got a HEX nut on the end you can use the hex fitting on the end of a battery drill.
    I always use them when im attaching a sign to IBR sheet could also work for this.
    16 January 2008 at 08:01
    I find the head on the roofing screws to large for panatrim frame, and they tend to bite on the frame before pulling it snug to the cladding.
    They are good though for fixing other types of signs.
    A little tip that I should have mentioned Warren,
    I always drill a hole dead centre on the top rail. mark out and drill just one hole in the cladding, and with the frame assembled (no panel)use just the one screw to fix initially. level up and mark the frame then drill the rest of the holes in the cladding.
    If its a long frame make sure the bottom rail is parallel to the top, as it can sag before fixing. or pre fix a couple of flat ally spacers between the top and bottom rails on long sections. so the frame stays absolutely square.
  • Peter Dee
    16 January 2008 at 08:21
    Warren, if you have any panel joins, make sure that the top rails are dead straight or the gaps will open up.
  • Warren Beard
    16 January 2008 at 09:08
    Thanks guys
    It is a single panel (2400 x 600mm), I was going to do the centre hole trick as this is how I usually do sign trays as I work alone 😉
    I have self tappers already so will be using these.
    Thanks again
    Warren
  • DaneRead
    16 January 2008 at 09:52
    hi for my interest can anyone explain to me what a panatrim frame is
    Ive never heard of this type of frame
  • Peter Dee
    16 January 2008 at 10:00
    16 January 2008 at 11:04
