Home Forums Sign Making Discussions Neon, LED, Lighting how do i fit 5×8 sky board sign to breeze block?
  • how do i fit 5×8 sky board sign to breeze block?
    Posted by Tris Gee on 18 August 2007 at 09:50
    hi every one.
    i need to fit a 5×8, 3mm sky board sign to breeze block. I’m framing the sign using unitrim frame from smp. now, i was wondering whether the frame is strong enough to drill and mount the top and bottom of the frame to the wall, slide the sign in and then attach the side parts. i thought by doing it that way, no visible fixings. just wondered if any one had any better ideas than this, as you can tell first time ive had to fit, and i don’t want a huge sign falling onto someone…lol
    tris
    Nicola McIntosh replied 18 years, 4 months ago 5 Members · 11 Replies
  • 11 Replies
    18 August 2007 at 09:53
    is that 5 foot by 8 foot or ?
  • Tris Gee
    18 August 2007 at 09:57
    hi Robert
    sorry, yes its 5 foot x 8 foot 😳
  • Fred McLean
    18 August 2007 at 10:05
    Should be fine as long as there’s enough fixings.
    But put the frame up complete,remove an end,slide the panel in and replace.
    F
  • Tris Gee
    18 August 2007 at 10:12
    i was thinking of drilling and fixing it 1 foot intervals just to be on sfe side.
    point taken about putting frame up complete, once board slid in though i wouldnt be able to screw that one side piece as board covering holes??
  • Fred McLean
    18 August 2007 at 10:31
    There should be small corner brackets on the frame ends to screw it all together.
  • Tris Gee
    18 August 2007 at 10:33
    oh right , i get you. thanks for advice, much appreciated
  • Fred McLean
    18 August 2007 at 10:38
    Should have been a bit clearer,you shouldn’t need to fix the two uprights to the wall only top and bottom parts of the frame.
    F
  • Tris Gee
    18 August 2007 at 10:42
    right i get you, but as long as plenty of secure fixing that should be sound and safe. thanks
    tris
  • Fred McLean
    18 August 2007 at 10:50
    Yup 😀
  • David Rogers
    18 August 2007 at 12:44
    What’s ‘sky board’?
    18 August 2007 at 14:12
    quote David Rogers:
    What’s ‘sky board’?
    the new name for alu-color 😀
