Home Forums Printing Discussions Printer Ink How do I find out remaining ink on SP540V ?
  • How do I find out remaining ink on SP540V ?
    Posted by Gary Hazard on 16 August 2006 at 10:36
    Hi all
    The engineer printed a report out for me after he installed the
    machine last month showing the percentages of ink left in
    each cart but I must not have been paying attention in all the
    excitement 🙂
    Anyone know how to do this either from the console on the machine
    or via Versaworks on the PC ?
    Trace
    Martin Armitage replied 19 years, 3 months ago 7 Members · 9 Replies
  • 9 Replies
    16 August 2006 at 10:43
    scroll thru the menu on the machine, and it has an option to see ink levels. On my sc540 anyway, yours would be the same I’d imagine
  • Gary Hazard
    16 August 2006 at 10:51
    Hi Shane
    Thanks for the reply
    Yep I can see the ink levels on the machine console but
    the engineer said that these weren’t that accurate.
    What I was after was a "printed" report showing the ink
    levels as a percentage.
    Trace
    16 August 2006 at 11:04
    hhmm didn’t know you could do that at a user level. Thought that was only a tech level. He’s right too, they are not that accurate…. 😉
  • Paul Hodges
    16 August 2006 at 12:17
    I thought the most recent firmware upgrade sorted that problem out?
    I certainly noticed the ink levels now seem to be correct in our machine anyway…
    16 August 2006 at 14:17
    in colour rip you can see them under status
  • Marekdlux
    16 August 2006 at 16:05
    In Versaworks, double click on the little picture of the printer in the top left corner of the screen. It should have ink levels on there somewhere, (don’t have the program open in front of me).
    I never check personally, I always have enough ink in stock so it doesn’t matter if one is low.
    -Marek
  • Gary Hazard
    16 August 2006 at 16:19
    Hi again guys
    Thanks Paul, Chris and Marek for your replies
    The more I look into this the more I get the feeling that
    it is something on the service menu that the Roland engineers
    can access but normal "end users" can’t
    I should get a call back from Roland tomorrow with a definitive
    answer hopefully.
    Marek, I’m not unduly worried about ink levels just trying to work
    out how much ink each banner is using so I can check that my pricing
    is somewhere in the right ball park.
    Some banners I’ve done are full coverage whilst others are only
    probably bout 40-50%
    Gaz
  • Rodney Gold
    16 August 2006 at 18:17
    The percentages the machine shows are meaningless , the cart resets the counter to 100% if taken out and reseated. So if you have ever removed a cart – your display of ink remaining is all cockeyed.
    The only sure way is weigh a full and then an empty cart and weigh yours to work out ink left. The newer gen machines have a way of reading the cart chip (all carts now have chips) to monitor ink levels , I also think this chip thing is to stop aftermarket carts being used.
    Usage will be round 12-18 ml per sq meter of all inks on a prety heavily printed banner – a little more with full dark solid coverage.
  • Martin Armitage
    17 August 2006 at 09:53
    scroll through the menu on the versacamm and print out a status report this will show percentage ink levels, although they are not accurate as far as i know.
