Home Forums Software Discussions Corel Software how do i fade a photo in corel 12/ photo paint please?
  • how do i fade a photo in corel 12/ photo paint please?
    Posted by Hugh Potter on 31 October 2007 at 22:58
    hi, i need to fade a photo which will be printed and put onto a silver car, as per here http://www.uksignboards.com/viewtopic.php?t=30695,
    how can i do this in corel photo ? i’ve tried messing with brightness, colours, hue, etc but just succeed altering the colour / image properties, and not making it fade, i know i could put a transparency layer over it in coreldraw, but wondered if i can do it in photo, i rarely use it so mucho help would be appreciated.
    TIA,
    Hugh
    Hugh Potter replied 18 years, 2 months ago 6 Members · 13 Replies
  • 13 Replies
  • Andy Gorman
    31 October 2007 at 23:03
    If you want to just fade the whole thing evenly then you should adjust the opacity of the layer. If you want to fade just the edges then one way is to use a big eraser with a soft edge and lowered opacity and rub out the edge. Loads of ways…..
    31 October 2007 at 23:14
    If you mean fade to the edge hugh, try use the Vignette filter Effects/creative/vignette
    1 November 2007 at 08:25
    Or feather for just the edges.
    Alan D
  • Tim Painter
    1 November 2007 at 08:42
    Or create a mask.
    Then:
    Mask
    Mask Outline
    Feather (Adjust the width etc) OK
    Cut to the clipboard then paste in as a new object from clipboard.
    1 November 2007 at 14:25
    thanks all, i’ll have a play using your suggestions.
    Hugh
    1 November 2007 at 17:15
    hmmm, as Andy first mentioned, i want to simply fade the whole image, i’ve used the vignette filter with some degree of success, but still need to fade the rest of the image, another way is to place a layer over the top and use the transparency tool in draw.
    i can’t find a tool or anything named ‘opacity’, so do not know how to alter it,
    any ideas please ?
  • Nick Minall
    1 November 2007 at 17:25
    Use the transparency tool in Draw.
    Nick.
    1 November 2007 at 17:32
    Hugh create a mask over the whole image, select the interactive transparency tool, then flat then adjust, if you are trying to make the picture "see through" then if you are printing to clear vinyl, the silver of the van/car will make the image partially see through anyway, and not very clear
  • Andy Gorman
    1 November 2007 at 17:48
    Hugh, in Paint (X3) it’s referred to as an object. There should be a slider on the right of the page that lets you adjust opacity under the objects tab.
    1 November 2007 at 18:14
    hi andy, i’m using 12, i guess it’s still referred to as object, but it couldn’t figure it as i was looking for opacity!!
    Peter and Nick, thanks, pretty much as i was trying to do, have rarely used the transparency tool so i’ll have a play with it’s settings.
    thanks.
    Peter… is there any way of demonstrating how much different it’d be if printed on clear, to std vinyl or is it a case of doing samples ?
    cheers.
    Hugh
    1 November 2007 at 20:32
    hugh, samples would be the only reliable way, the silver of the van being the factor that would most influence the appearance, a very light silver, could almost, but not quite, look like white, whereas a dark silver would not really be good for a clear print.
    2 November 2007 at 08:35
    Hugh, in Photopaint V12 (same for X3)
    Open image
    Open object docker (windows tab – dockers – objects or ctrl+f7)
    Look to icons at bottom of docker
    2nd icon from left ‘creates an object from the background’
    Transparency slider will appear at top of docker, just slide until desired transparency is achieved.
    This will make the entire image transparent.
    Alan D
    2 November 2007 at 10:42
    cheers Pete, and Alan, many thanks, i’ll give that a go in a mo.
    Hugh
