Home Forums Sign Making Discussions Graphic Design Help how do i enlarge this logo correctly?
  • how do i enlarge this logo correctly?
    Posted by David_Evans on 28 October 2007 at 21:55
    Ive been given this image as part of a psd. The problem is it is only around 4x2cm at pretty good resolution but the client want it printing at 700mm tall. Obviously at this size i would be heavily pixellated so i need to redraw in vector can anyone shed any light on how i might do this as normally only design for cut vinyl so have no idea where to start. i use illustrator.
    All help greatly received.
    David_Evans replied 18 years, 1 month ago 4 Members · 10 Replies
  • 10 Replies
  • Kevin Flowers
    28 October 2007 at 22:01
    looks like its been designed in Photoshop using plugins, so probably best to redraw in Photoshop at a larger size. Alternatively you may be able to get a good result with something like Photozoom.
  • David_Evans
    28 October 2007 at 22:36
    Kev,
    My photoshop skill are pretty poor so will have a look at the photozoom thing. If the client has the original photoshop file is it just a case of resizing it or will it have to be redrawn at the size i require?
  • Kevin Flowers
    28 October 2007 at 23:07
    not that conversant with PS myself, but use the plugins within Flexi. Do you have the original font etc
  • David_Evans
    28 October 2007 at 23:11
    Kev,
    I have the original psd they sent me. And have no probs opening it so a assume its not a font.
  • Bill McMurtry
    28 October 2007 at 23:38
    Photozoom wouldn’t give an appropriate result with such a small image being blown up to such a large size. Ask your client for a higher resolution version or you might have to rebuild from scratch, which wouldn’t be easy.
  • David_Evans
    28 October 2007 at 23:41
    pretty much what i thought Bill. Thanks
  • David Rogers
    28 October 2007 at 23:54
    Yeh, you really need a better original.
    I just blew it up to 700mm (resampled image too)…pretty poor original to work with so end result is a bit dodgy!
  • David_Evans
    28 October 2007 at 23:59
    Ill get in touch with the really helpful bunch tomorrow then and demand something better. Dont think ill get much though!!
    Thanks chaps
  • Kevin Flowers
    29 October 2007 at 00:01
    can duplicate the effect if you can supply font or vector etc, took 2 mins with plugin. Can make it a harder bevel etc
  • David_Evans
    29 October 2007 at 00:13
    Kev,
    Thanks mate. Can you pm me your email and ill send over what i have.
