Home › Forums › Software Discussions › Signlab Software › how do i edit the text spacing in signlab 8 please?
Posted by Richard Urquhart on 2 February 2009 at 17:28ok may be an easy one I’m missing here
you make a line of text and want to get say 2 characters off the base line how do I edit the text in the above
please help going mad here
Alan Drury replied 16 years, 9 months ago 5 Members · 13 Replies -
ok you type a word out like sign’s and want a little s on the end and you want it up higher and smaller, can get the s smaller but need to know how to get it up off the base line
thanks Rich -
can do that no probs but in flexi you can just tell it a size from baseline and job done is this the only way???
Richard,
If you select the last 2 characters of the line ie: the N & S you will notice that underneath the box that adjusts the kerning (letter spacing) you will notice 3 buttons A², A2 (this should be a small 2 on the base line)and A2.
if you click the A² the S will become superscript – well it does in SL7.Steve
That works but can you change the amount in which it comes off the baseline??
Same as steve but if you right click the subscript/superscript box you can adjust the variables
I don’t know, I wouldn’t have thought so SL is a bit crude as a text editor. What happens if you make the S a little bit smaller before you apply the superscript function, say all the text is 50mm reduce the S to 40mm then apply the function.
Oh gosh that is just what I wanted Peter , Steve and Lynn I will now sleep well I knew there must have been away to do this, really need a signlab book ho did you learn all the little bits in Signlab. I really like it and saves me so much time when printing just need to learn more.
Er don’t know what Peter said but if you right click the text with the button selected you can change it – just found that out while fiddling.
I’m well behind here with the replies – I have a manual that came with version 5, it about as much use as chocolate teapot.
I think I’ve learnt most from the videos I got with version 7, the ones available on the Cadlink site and a good deal from this site ie: Peter and Nick Minall.
There used to be Cadlink tech who visited the site but I haven’t seen him post for a long time.Steve
The manual that came with flexi sign was massive, any thing you needed to know was in it, the one that came with signlab 8 is about 20 pages !!
would like to buy a complete cd I have looked at the videos and have got most thing sorted .
Rich -
I agree with Steve for a high end, bespoke sign programme SL text handling is down right poor, if Cadlink were to compare it to Corel and some of the others they would realise how far behind it is.
The A2 solution is the most practical one I know of – but how clumsy.
Alan D
