Home Forums Software Discussions Corel Software how do i do automating spacing objects in corel?
  • how do i do automating spacing objects in corel?
    Posted by Gary Davis on 25 April 2005 at 13:48
    I need to repeat an object around 50 times with a 2mm space between each. Is there any easy way of doing this in corel?
    without guidelines and lot of duplicating?
    thanks
    Alan Drury replied 20 years, 8 months ago 3 Members · 3 Replies
  • Rodney Gold
    25 April 2005 at 14:35
    Use align and distribute or DL a script called “aligner”
    http://www.isocalc.com/cooltools/
    Its free and real easy and of course you can DL a whole host of other free utilities
  • Vitor Brito
    25 April 2005 at 15:09
    I think Rod’s solution probably sorted you out already, but i think you could easily do it in Corel as well, anyway here it goes for future reference, you just need to set your duplicate distance previously to the size of your object + 2mm, and then use control+D to duplicate it as many times as you need. Sounds like what you asked was exactly not to duplicate but i would do it this way, afetr all you just need to set the duplicate distance once and then press Control and without releasing it press 49 times D key. If you use the aligner i think you would have to count it anyway.
    Just my 2 cents. 😕
    Britchenko
    25 April 2005 at 15:28
    Worth looking at http://www.oberonplace.com for loads of free and useful stuff.
    Alan
