Home Forums Vinyl Cutter Discussions Mimaki Cutters how do i detect the registration mark Type 1 on plotter?
  • how do i detect the registration mark Type 1 on plotter?
    Posted by tived on 14 January 2008 at 04:05
    Hello,
    I am very new to all this, and my partner is away on holidays. and I am doing a couple of jobs print and cut.
    using Flexi 8.1 and Mimaki JV3-130SL and CG-130FX cutter.
    and for some reason two of my jobs came out with type 1 registration marks instead of Type 2?
    I don’t seem to be able to detect them, where to place the cutter head/laser ? I have ruined one job already! 😳
    I am trying to decode the manual,…but I am not having much luck.
    any help would be appreciated
    Henrik
    tived replied 18 years ago 2 Members · 2 Replies
    14 January 2008 at 09:16
    Henrik, type one or two dosnt really matter as long as the plotter is set to regognise them, Is the reg mark function switched on in the plotter? if it is, the laser should light up after detecting the media size. move the dot into the area of the reg marks and press enter it should then detect all the marks, 2,3,or 4 as set by the programme and in the plotter set up.
    If you take out the blade holder before cutting you can check if all is ok with a dummy run
  • tived
    14 January 2008 at 23:20
    thanks Peter,
    great idea, I will go an play with it today.
    thanks very much
    Henrik
