Home Forums Sign Making Discussions General Sign Topics How do I create a curved face on a Diabond sign?
  • Fred McLean
    17 August 2009 at 13:33
    Bend it 😕
    Depending on what your putting it onto(if it’s a pre-curved backing
    screwing it on as you go along might suffice.
    If it’s free standing of any description it might have to be bent by an engineering co. with a set of rollers
  • Ruairi O'Boyle
    17 August 2009 at 14:30
    Thanks Fred.
    Was in a rush earlier and dint explain myself well in that email.
    I am trying to put a dibond face onto a metal frame (which will have curved cross beams). The frame will be 1000 – 1200mm wide and I would like the dibond to curve outwards by about 150mm in the middle. Will I be able to bend it without distorting the face? I had thought about routering out lines on the back face to make it more flexible.
    What do you think?
  • Fred McLean
    17 August 2009 at 15:05
    hi Ruairi,
    I think if you rout lines in the back you will probably see them as steps on the front.
    from sizes you’ve given the dibond will more than likely take the bend no problem.
    i would start fixing in the middle and work left then right though 😀
  • Ruairi O'Boyle
    17 August 2009 at 15:30
    Cheers Fred Ill give that a go. I just thought of the routed version as someone had said if I take out the aluminium and not the plastic on the back side then dibond was easily curved.
  • Fred McLean
    17 August 2009 at 15:43
    Removing the alum and leaving the plastic makes for easy bends and i’m sure it will leave stress lines on the front of the panel when you come to bend around the sub-frame 🙂
  • Michael Dunn
    18 August 2009 at 12:35
    this will show you what it seems you are wanting to know
    http://www.uksignboards.com/viewtopic.p … bond+curve
  • Fred McLean
    18 August 2009 at 12:51
    I stand corrected about tram lines on the show face 😳
  • Ruairi O'Boyle
    18 August 2009 at 12:52
    Thanks Michael but as per a few other threads I was looking at I cant see any pictures! Am I blind?
    Might be the fact I am using google chrome might go try Internet explorer just to be sure!
  • Ruairi O'Boyle
    18 August 2009 at 12:56
    Nope I cant see any pics! have they been removed for some reason?
    Fred – i tried it before but went to deep and ended up with tram lines! i think if you just loose the aluminum and no more then it works fine! Someone else might confirm this for me!?
  • Fred McLean
    18 August 2009 at 13:08
    Are you logged on?????
    You wont see pics if you’re not!!
  • Ruairi O'Boyle
    18 August 2009 at 13:17
    I am logged in and I believe I have purchased the full package!
  • Ian Johnston
    quote Fred McLean:
    :lol1: :lol1: keep the groves close enough and don’t router too deep and they wont show, i’ve been using this method for a few years now, and have had great results,
  • Michael Dunn
    18 August 2009 at 13:19
    are you logged in?
    if not you won’t see any photos????
  • Ruairi O'Boyle
    18 August 2009 at 13:20
    cheers Ian thats a great help!
  • Ruairi O'Boyle
    18 August 2009 at 13:29
    Sorry guys you were right! I said I was logged in at the top of the page but when I logged out and logged back in again it worked fine!!
    That reception area looks class!
    Thanks for all you input!
