Home Forums Sign Making Discussions General Sign Topics How can we cut Correx?
  • How can we cut Correx?
    Posted by John Stevenson on 9 August 2006 at 07:35
    We’re using 10mm Corex (actually Euroflute from Europoint) for the first time and having difficulty cutting across the flutes.
    Obviously cutting the length of the flutes is easy but what’s the best way to cut across?
    John Stevenson replied 19 years, 4 months ago 5 Members · 9 Replies
  • 9 Replies
  • Matt Hards
    9 August 2006 at 07:50
    I cut 5mm, 10mm correx and foamex all in the same way. Use a straight edge, I have a brilliant one from hexis, with a non slip backing. and protects your fingers.
    With a sharp, or new stanley knife, just run it along the straight edge fairly lightly, usually a couple of passes will do it. I find going either way over the flutes works fine, obviously easier length ways.
    In what way are you having a problem, i.e. going wonkey donkey or just not cutting???? 🙂
    Matt
  • John Stevenson
    9 August 2006 at 08:08
    OK Matt
    Thanks for that.
    Perhaps we were just being a wee bit tentative as it’s our first time.
    I’ve tried your advice and been reasonably successful now
    9 August 2006 at 09:35
    john get europoint to cut it for you in the future, but i think it takes an extra day for it to be delivered 😀
  • John Stevenson
    9 August 2006 at 10:09
    Good thought Nik – hadn’t realised that was possible.
    Asked now and apparently their guillotine is broken but we’ll remember that in future.
  • Brian Little
    9 August 2006 at 11:07
    john im sure theres a "tool for the job " i think jag sign supplies do them .might be worth looking into if your doing a lot of it …on 01409 254 370
  • John Stevenson
    9 August 2006 at 14:50
    Thanks Brian
    Got that from JAG – it’ll make cutting with the flute very easy.
    Any clever ideas for cutting across the flute?
  • Brian Little
    9 August 2006 at 15:55
    hmm nope sorry john dont have much experience of the stuff but im sure nik etc will be able to help
    regards
  • Robert Berwick
    10 August 2006 at 13:09
    I guess the same principles would apply as when cutting foamex by hand.
    See this tutorial by Rob Lambie:
    http://www.uksignboards.com/viewtopic.php?t=17574
    This is the way we cut correx against the flutes.
    Robert
  • John Stevenson
    10 August 2006 at 19:43
    Thanks Robert
    as usual, Rob’s video was very helpful – we’ve got it sussed now.
    PS, good luck to the Linnets in the new season
