Home Forums Sign Making Discussions Neon, LED, Lighting how can i fix perspex to plywood?
  • how can i fix perspex to plywood?
    Posted by Andy@Acorn on 4 November 2003 at 11:39
    Need help how can I fit a perspex 5mm panel 1400 x 1100 to ply wood
    that has been fitted to a brick wall?
    The perspex is clear with a full colour image in reverse backed up in vinyl
    can I just screw fix making sure the holes in the persex are quite big?
    HELP
    Andy@Acorn replied 22 years, 1 month ago 4 Members · 6 Replies
  • Simon Clayton
    4 November 2003 at 11:56
    I would recommend putting in a panatrim frame,
    Perspex is brittle and expands alot
    Simon
  • Rodney Gold
    4 November 2003 at 12:08
    If you are using Cast Acrylic , the acrylic expands in all directions , extruded expands along the direction its extruded – make your holes oversize to accomodate expansion , like a 3mm hole make 5mm and use a washer. you might need more than holes at each corner for that size perhaps 3 holes per side – dont screw the screws real tight , leave enough so that the perpsex “slides” as it expands.
  • Andy@Acorn
    4 November 2003 at 12:37
    We are unable to use a panatrim frame as it is fitting into a recess, so I think it has to be screwed in, what could I use to cover / disguise the screws?
  • Adrian Howard
    4 November 2003 at 13:42
    SMP do a front fit pantrim type frame called rollerbead
    http://www.signmakersproducts.ltd.uk/
  • Simon Clayton
    4 November 2003 at 14:26
    Panatrim was designed to be used in recesses
    Make sure you tell them when ordering that it is to be front-loaded
    Simon
  • Andy@Acorn
    4 November 2003 at 15:49
    Forgot to say the panel has a cut out section at the top so not able to use a trim. Need to fit in morn so not got time to buy anything special in
