Home Forums Software Discussions Signlab Software how can i connect my dell with parallel port to signlab?
  • how can i connect my dell with parallel port to signlab?
    Posted by Peter Coogan on 2 August 2006 at 08:34
    I have just purchased a new Dell computer but there is no Parallel port on it, at the moment I am using Signlab 4.95 with a Parallel Dongle going through my Printer on my old computer ( the printer has a parallel port connector & my Dongle is connected to that) as I am about to upgrade to signlab 7.1 and am also buying a new printer which will have a USB connector on it where will I connect my Dongle Hope that does not sound to confusing
    Gordon Forbes replied 19 years, 3 months ago 8 Members · 10 Replies
  • 10 Replies
  • Adam McGuire
    2 August 2006 at 08:52
    I think the dongles are available in USB as well these days. I’m not too sure though!
    Can you not use a USB to Parallel cable? For your printer? Admittedly you wouldn’t be able to use your existing dongle….it’d just save you buying a new printer….
    Adam
    2 August 2006 at 09:09
    its a usb now but I think cadlink charge extra for the dongle upgrade?
  • Steve Morgan
    2 August 2006 at 09:12
    Peter,
    When I upgraded to 7.1 my old dongle was changed to a USB dongle. No idea what you do with the old parallel port cable, but there are a few people on the boards who are self confessed computer geeks, who will certainly be able to point you in the right direction.
  • Peter Coogan
    2 August 2006 at 10:22
    Thanks folks for your help I believe Cadlink want an extra £75 for a USB dongle that is the reason i would want to use my old one
  • Steve Curry
    2 August 2006 at 10:56
    Yes it is £75.00 for a USB dongle I have just bought one, BUT you can get a parallel port PCI card and install it into your computer then carry on using your parallel dongle, I did this on another computer bought recently, I think the card costs about £20.00 and their quite easy (plug & play) to install, it just depends if you want to open the back of your computer or not, I don’t know what dells warranty issues are if you add extra components.
  • Peter Coogan
    2 August 2006 at 12:12
    Thanks Steve thats the answer I have looking for thanks alot
  • Paul Franklin
    2 August 2006 at 19:24
    If you are installing a card to give you extra parallel / serial ports for dongles or printers I’d advise you to get one that supports ECP (Enhanced Capabilities Port). Otherwise you might have problems.
    As an Edge II user I had to use this type of card or the Edge wont work, and the old serial dongle (now upgraded to USB) needed to have an ECP port also.
    2 August 2006 at 19:32
    From past experience , I would just pay the £75 Trust me it will save you a lot of hastle..
  • Peter Coogan
    3 August 2006 at 11:44
    Think I will take your advise and purchase the USB Dongle
    Thanks Pete
  • Gordon Forbes
    5 August 2006 at 03:21
    Parallel to USb forget it a lot of them don’t work
    Do a google on it I bought one and didn’t find out till later wasta a bloody money
    Goop
