Home Forums Software Discussions General Software Topics How best to start
  • How best to start
    Posted by Richard Fulford on 28 January 2008 at 21:46
    hi all
    I am new to sign writing in vinyl. Can you help with is what I have a good package?
    I purchased a small existing business, and he was using, Omega 1.56, and Jasc Paint Shop.
    At present i have got a design i created in Omega, a two colour design. But the problem i have is that i have two separate pieces in the same colour that are on different layer, one with the light background, the other with the dark backgound and a light foreground. So when i print it or e mail it to client, one is hidden by the other colour.
    I hope that makes sense.
    Or should I not be trying to design in Omega?
    Richard
    Richard Fulford replied 17 years, 10 months ago 5 Members · 9 Replies
  • 9 Replies
    28 January 2008 at 22:28
    Design packages have a feature that allows you to re-arrange the layers. I wouldn’t know how to do it in Omega – but you need to find a function that allows you to select each object and arrange it’s position relative to any other objects in the drawing. Usually this means sending to front or rear the particular object that is selected
  • Ian Johnston
    28 January 2008 at 22:35
    select every thing and click on a vinyl colour that you want to use,found at the very bottom LHS of you screen to change all vinyls to that colour,
    if that makes sense!!
  • Karl Williams
    Go into Arrange and you will see at the top "To back" and "To front".
    You have to make sure that the layer you want to move is selected in order to move it.
    Karl.
  • Richard Fulford
    28 January 2008 at 22:49
    I can select the darker colour, bring it forward, but then it covers the lighter colour i have else where in the design that i want in the foreground.
    should it be cut out to reveal the lower layer, if so how?
    Richard
  • Karl Williams
    28 January 2008 at 23:04
    Sorry mate but can you explain a bit clearer? if you bring an image from the front to the back then it will overlap if the other image was overlapping already. The first program I used was Graphix advantage then Omega took over. I had to teach myself as well as learning how to use a p.c. You have to play on it for hours to grasp it. When you work it out you will find it’s a great program to use.
  • Richard Fulford
    28 January 2008 at 23:56
    hi karl
    basically i have a logo that its light green with a dark green background and the lettering is dark green with a light green surrounding background.
    i hope thats clearer.
    other than this i have found omega to bit very good.
    Richard
  • Karl Williams
    29 January 2008 at 00:11
    Richard, I’ve just tried it mate. you are using the foil colour palette. You have to ensure the cuts on is selected or cuts off selected.
    if you want to use vinyl only use the palette at the bottom.
    Karl.
  • Mike Grant
    29 January 2008 at 20:59
    You will probably find the program will only layer the same colour on one level. (if it is like Graphics advantage – it’s predecessor) I get around this by using the closest alternative shade and re-colour the object that keeps disappearing.
  • Richard Fulford
    30 January 2008 at 07:52
    Hi All
    Thanks for all your answers. I have now used the last suggestion of changing the colour slightly. Works a treat, just have to remember that need to change it back before cutting so as to include it with right colour.
    I am new to this site and it is very good to have such a good response, well done all.
    Richard
