Home › Forums › Printing Discussions › General Printing Topics › How are these flag banners printed
Posted by Nathan Hill on 3 March 2011 at 23:23Any idea how these are produced. We have a versacamm but surely these weren’t printed on one of these. Have had a couple of enquiries and could do with some info. (?)
David Rowland replied 14 years, 9 months ago 6 Members · 10 Replies -
I used to print these at my last job, we did them on a textile printer " a mimaki tx2 " using dyes, I’m not sure if you can print these on a versacamm.. maybe someone else will know this.
have found with some suppliers they take a while to get printed..
TX2 or Agfa/Gandi Aquajet are printers i know of
I tried printing the on a solvent before… don’t bother its a waste of time.
Thanks Guys maybe I’ll try and buy them in printed and just pass them on.
I’ve tried every ‘flag’ material with every setting known for the versacamm trying to do in-house flags.As Dave suggested ‘don’t bother.
Once you see the results next to a dye sub system or a textile printer you realise you have to buy in.
We buy these complete from Ultima Displays. They will even ship direct to your customer saving two lots of postage charges.
Kind regards
Russell.
Why do you guys say they cannot be printed with an eco solvent printer?? I print these with excellent results on my Roland printers. I’m printing one on Monday. I’ll take a picture and post it here.
The flag material does not give good results. When I have to print on it, I select the lowest head speed, mono directional, high quality with double overprint. Takes forever, and quality is so-so..
The stuff I’m currently using is called K20. It prints better than anything else on the SP / RS. Solid, vibrant colours.
where do you K20 from please Gert? and are the results comparable to dye sub or other fabric printers?
when the mimaki textile printer was out of action, i had to try to print flags using the solvent printer.. it printed but the colours looked washed out and looked terrible like a faded flag, we used a polyester nylon flag material.
If your customer knows what these flags are susposed to look like then they wont be pleased if you print with solvent and they may demand a reprint… it happened at the print firm i was working… a lot of time and money lost.
I have not heard of this K20 material, maybe it does sort of work, but its still a risk.
Gert du Preez.. do you not have problems with your ink soaking through the material using double pass ?
Andy,
Yes, on flag material you do get some "bleeding" of the ink. That is why I print high quality, with the head speed at it’s slowest setting. On the SP540, which is rather slow, these settings are VERY slow. With the pre-heat and dryers up to max, it gives time for the ink to dry without much bleeding. But, like I said, the quality is still nowhere near proper dye-sub printing.
Play with profiles and different flag materials. The flag material I use is made by 3P textiles (from Germany I think)
The K20 is a different story.I get it from a supplier in South Africa. I have no further details on it – there is no markings on the roll etc. to indicate who produces it.
Like I said, I’ll post some pictures come Monday.
buying roll materials to print a few metres is not profitable.
we printed some but we cannot offer it as a inhouse print service as it looks terrible.
I have started to print with UV tho, seems to work
