Home Forums Vinyl Cutter Discussions Roland Cutters horizontal lines throught the print problem
  • horizontal lines throught the print problem
    Posted by Dan Osterbery on 21 April 2010 at 11:12
    Hi All,
    we are using a polymeric vinyl and the correct profile and we are getting horizontal line through the print? We have been using this combination for 5 years and only now are the lines appearing?? can anyone point me in the right direction to solve this? We have done head cleans, bi directional adjustments etc and manually cleaned the machine?? is one of the print heads wearing out? is there a way to check?
    any help appreciated!
    regards
    Dan
    Chris Wool replied 15 years, 8 months ago 3 Members · 5 Replies
  • David Rogers
    21 April 2010 at 12:19
    I take you’ve done all of the nozzle test prints & alignment checks.
    Are the lines light or dark?
  • Dan Osterbery
    21 April 2010 at 12:23
    yes! the lines are light?
    21 April 2010 at 12:59
    have you ever altered the feed print calibration. this come up the other day.
    i ended up putting -.01% in and all was well.
  • Dan Osterbery
    21 April 2010 at 13:16
    no havent touched it but will check it! just printed a test print and the two squares were not solid, but made up of dots?? i’m sure that last time i did it they were solid??
    regards
    Dan
    21 April 2010 at 13:55
    they are made up of dots but should not overlap or be spaced apart, just touching.
    i used a magnifying glass in the end.
    as you say been using the same material for a long time just that day caught me out.
