Home Forums Sign Making Discussions Vinyl Holographic Vinyl Supplier Suggestions?
  • Holographic Vinyl Supplier Suggestions?
    Posted by David Hammond on 29 October 2012 at 15:57
    I have a customer looking for some silver holographic vinyl stars cutting.
    I know graffityp do a textile material, but can’t seem to find a supplier for the self adhesive holographic vinyl.
    Any suggestions welcome.
    Gary Birch replied 13 years ago 7 Members · 14 Replies
  • 14 Replies
  • Cheryl Smith
    29 October 2012 at 16:03
    Hexis…I think?
  • Reza Faezi
    29 October 2012 at 16:07
    Vinyl Corp?
    29 October 2012 at 16:15
    Had it from both the companies mentioned David but if it hasn’t changed then it is only a display type film, not suitable for outdoor use so customer needs to be made aware of that.
    Having said that I put it on a number of cars for people despite warning them against it & it held up very well.
    29 October 2012 at 16:16
    The vinyl is going on 4mm black correx, internally. It only needs to last 6weeks… but will be re-used over 3 years.
    Customer warned me it was expensive 😮
    All above £10 PLM.
    Doro tape does one at almost 1/2 that price? 😕
    29 October 2012 at 16:21
    If it’s not a rush job then get a couple of samples from each David, bit difference in the finish of some of these films. There is also another company I used years ago that had holographic in its name try a google search.
    29 October 2012 at 16:24
    Think it may have been these people but not 100% sure
    http://www.holographicvinyl.co.uk/
    29 October 2012 at 16:26
    Not so much a ‘rush’ job…
    It’s a big enough order to warrant buying it in, but not the kind of job that warrants a massive cost. 🙄
    Just looking at their website now Martin.
    29 October 2012 at 20:20
    you will find several sources on the UKSB toolbar mate. see vinyls, then decorative films…
    same listings are now on Signapp directory also.
    Best price on this stuff I have found to be creative films, http://www.creativefilms.co.uk but their pricing doesn’t seem very stable. Still, worth buying from them as they are competitive.
    We bought various styles of 50 metre rolls and paid around £2.35 a metre (some years back now) then sometime after 20 metres here and there and the price had risen substantially. I do get the bulk buying and all that, just that there was so much a jump.
    Anyway, they also have a great range of films available.
    David these are polyester foil films mate and aren’t forgiving and show up dust like mountain. So make sure perfectly clean and maybe do a sample on correx as I recon the ripple of the surface may create bubbles between flutes. Could be wrong though, but once this is down it’s down. Try lifting and re-laying and the adhesive comes away from the film.
    30 October 2012 at 10:29
    Cheers Rob.
    Creative films have a minimum order of £50.
    Probably go with Martins link.
    Good news is that I am not fitting the vinyl, just supplying the correx and the vinyl for the customer to fit themselves.
    30 October 2012 at 10:40
    sorry mate, never knew that. must be a new thing or it was never mentioned due to us buying in high volume.
    good to hear on the fitting, nothing worse with correx. 😀
  • Stuart Miller
    1 November 2012 at 15:08
    I used this `Bright Overall` vinyl from Dorotape reverse fitted to the back of a glass plate to be installed in a shower. Came out well and believe still Ok after a couple of years .
    Dorotape give it 5 years exterior life !
    Not sure if that’s what you mean by holographic.
    Hexis do this also.
    http://www.reflecta.co.uk/viewbigimages.aspx?imgname=Pearl-Shower-Screen-450.jpg
    1 November 2012 at 17:31
    I actually bought it from Solar Sign Supplies over in Chester. I’ve used them for odd little bits, and they send a brochure out with a free delivery voucher… price on the film was good and saved me delivery.
  • Gary Birch
    2 November 2012 at 06:49
    Not certain but I think that ATC (Application Tape Co) in Rochdale do it too
    Gary
  • Gary Birch
    Gary
