Home Forums Sign Making Discussions Neon, LED, Lighting High quality built up letters and advice required
  • High quality built up letters and advice required
    Posted by Warren Beard on 20 May 2010 at 13:32
    Hi All
    I haven’t done much in the line of built ups so wanted to ask what is the highest quality built up you can get, what I mean is the one that gives the nicest possible finish which needs to be white.
    It will be viewed close up and is for a very upmarket client and they want the best 😮
    Warren
    Gary Birch replied 15 years, 6 months ago 4 Members · 4 Replies
  • Dave Harrison
    20 May 2010 at 14:17
    How you doing Warren
    The best I’ve seen came from applelec if I remember correctly. They were built up stainless steel, with a polished mirror finish, they had been finished so well the join between the face and return was almost invisible !
    What size are these letters, As you want them coloured (white ) I would have thought the best finish would be obtained from either descaled stainless steel or aluminium with a with a powder coat or baked finish. Either that or if they a small laser cut solid acrylic !
    All the Best !
  • Martin Cole
    20 May 2010 at 16:47
    Hi Warren
    as Dave says, Appelec do them. They can maufacturer but they can also import some from the states I believe, which they told me were top notch with virtually invisible joins…sounds like the ones your after.
    I had to get a qoute for some in white around xmas time and they gave me the two options, worth a call ask for Sam or Zoe
    Martin
  • Richard Urquhart
    20 May 2010 at 17:25
    I had a great job done by GDI
  • Gary Birch
    20 May 2010 at 19:04
    Another vote for Applelec here too. Always very helpful
    Gary
