Home Forums Printing Discussions Sublimation Printing Hi Viz quilted Jacket pressing question
  • Hi Viz quilted Jacket pressing question
    Posted by Jeremy Howes on 14 May 2010 at 19:09
    Hello,
    I have a one off Hi Viz quilted jacket/coat to heat press with a black garment film, the outer fabric is a yellow 100% Polyurethane coated Polyester.
    1) which would be the best film to use?
    2) can the quilting pose any problems that I should look out for?
    Thanks for looking, grateful for any help with this.
    Jeremy
    Jeremy Howes replied 15 years, 7 months ago 4 Members · 7 Replies
  • 7 Replies
    14 May 2010 at 19:13
    i use a pillow to localise the pressure, done several no problems.
  • Neil Speirs
    14 May 2010 at 19:19
    Some jackets have a inner zip at the bottom of the jacket to allow easier heat pressing
  • Nigel Pugh
    14 May 2010 at 19:35
    quote Chris Wool:
    With Chris on this, raise the area you will be pressing, as for material I would normally suggest what we call ‘nylon extra’ instead of the normal textile material.
  • Jeremy Howes
    14 May 2010 at 19:40
    Thanks for the replies Chris and Neil,
    Unfortunately there is no access zip, but having positioned the jacket over the press table it doesn’t seem to bad to press, the only film I have in stock is Poli-Flex supplied by Hexis, will the polyurethane coating cause a problem?
    Thanks again
    Jeremy
  • Jeremy Howes
    14 May 2010 at 19:59
    Thanks Nigel,
    I’ll be using the DK8 heat press for this and probably press in two hits….Poli-Flex is ok for Polyester, just wondering if the Polyurethane coating would cause adhesion problems.
    Jeremy
  • Nigel Pugh
    14 May 2010 at 20:09
    Jeremy I take it that the poli-flex is the standard type of flex used on the majority of cotton, poly, poly-cotton garments. If it is then my advice would be to apply at the usual temp but extend the application time to allow the adhesive to soak into the jacket itself rather than just its coating.
    So if 15 secs is the norm I would myself extend the time to 25 secs, if the garment can take the longer time the flex will do easily, on saying that I have never used Hexis material, but I would assume the majority of flex supplied comes from the same manufacturer.
  • Jeremy Howes
    14 May 2010 at 20:53
    Hi Nigel,
    Many thanks for the very sound advice, I’ll give it a go tomorrow.
    Jeremy
