Home Forums Sign Making Discussions Off Topic Chat Hi from Gloucestershire
  • Hi from Gloucestershire
    Posted by Chris Ranner on 4 December 2015 at 13:18
    my second post as I forgot to say hi here first!
    Just a quick hello into the forum, I’ve been lurking for a while and read the forum for hours while recommissioning my printer.
    I’ve got a Tiara Opal II, essentially a Mutoh Rockhopper II. I got it over the summer and have recommissioned it and for 6-8 weeks its been running really well, just got an issue with a new media I’ve got (but I started that in my other thread so I won’t go into it here). I’m using a budgetish vinyl to run through the printer when I’m not printing on my main media
    I acquired the printer because everyone I spoke to wouldn’t touch the media I wanted to print onto, it’s a specialist PET & PU clear for making wakeboard and snowboard top graphics and most baulked at it when I explained what it was. So, given this I’m a complete newbie with this stuff and not come from a signwriting or digital printing background but been thrust into the work at warp speed! So please excuse any incorrect terminology and possibly naive questions.
    Chris
    Tahsin Niyazi replied 9 years, 10 months ago 8 Members · 9 Replies
  • 9 Replies
  • Christopher Montgomery
    7 December 2015 at 12:36
    Hi Chris, welcome to the boards!
    Please also consider uploading a picture of yourself 😀
    8 December 2015 at 09:24
    welcome to the boards chris, great to have you here.
    Not sure the material that you’re after as i don’t know what the boards are made of or the surface finish you are applying to as such. Do you know what other manufacturers are using for same?
  • Chris Ranner
    8 December 2015 at 16:27
    The material I have is a modified 0.5mm thk clear TPU/ABS with corona treatment, I’ve done a couple of test prints on it so far. I’ve got 4 different types to play with to begin with before I have to buy a roll and at £8+vat a metre I’m trying to get the most out of the samples I have!!
    The datasheets are useless and the manufacturer has basically said "do your own tests, I don’t know" !!
    @Chris Montgomery, how do you upload a photo? I can’t seem to find a user info mod button? (I’m probably being stupid though!)
  • Michael Kalisperas
    10 December 2015 at 19:49
    Surely a direct to board process possibly a uv ink is the best option for what your explaining?? And have you not tried a printable wrap material with quality high impact laminate ?
    13 December 2015 at 11:47
    Welcome to the forum Chris, can’t help with your printing issue personally but sure someone with print experience will.
    Best of luck with it.
  • Duncan Wilkie
    14 December 2015 at 00:09
    Welcome Chris. All the best.
  • John Singh
    16 December 2015 at 20:54
    Hi Chris
    Welcome to the boards 😉
  • Chris Ranner
    24 January 2016 at 12:52
    quote Michael Kalisperas:
    The boards are contoured and are not flat on any axis sand of variable thickness o wouldn’t be able to feed through anything that I could afford to use!
    The wrap is an option I’m looking into, there’s a local printer just up the road who will varnish a high impact coating onto it too, so many things to look at!
    Still having a few issues with banding on mainly the cyan (or it’s more noticeable on the cyan)
  • Tahsin Niyazi
    26 January 2016 at 01:52
    Welcome to the boards, Wishing you all the best!.
    Tas
