Home Forums Software Discussions General Software Topics Help with Versacam & VMP
  • Help with Versacam & VMP
    Posted by tonygoodall on 9 March 2007 at 16:25
    Hi all
    Hope one of you can help. I have just purchased a Roland SP540v and have just installed Vinyl master pro to cut my vinyl. i send the job from the spooler to the Roland, it says it is processing in the little display but nothing happens.
    Has anybody got any ideas on what i might have done wrong?
    It is really battering my head in and feel like taking a hammer to the bl—y thing.
    Thanks in advance.
    Tony
    Alan Wharton replied 18 years, 9 months ago 2 Members · 2 Replies
  • Derek Heron
    9 March 2007 at 16:53
    hi tony
    how is the machine connected i had problems with my machine and had to switch norton anti virus of everytime before i could send the job
    hope this helps
    Dex
  • Alan Wharton
    9 March 2007 at 17:09
    in vmp you have to be carefull which printer you have set in windows as your default printer ie your deskjet because when you send your file to print from vmp it will send to the default printer ie your deskjet! its a pain in the a, everytime i send a file to cut i have to click on the printer/cutter properties(in vmp) then advanced tab and from the dropdown window i then have to select my cutter, then the file will cut np, its a pain but it works.
