Home Forums Vinyl Cutter Discussions Summa Cutters Help with Summa cutter with reflective vinyl
  • Help with Summa cutter with reflective vinyl
    Posted by Gary Barker on 13 December 2016 at 09:08
    Hi All does anyone cut engineers grade reflective vinyl on a S class cutter, we will be using Oralite 6910 grade, if so what blade do you use, and helpful tips would be appreciated
    Thanks Gary
    Hugh Potter replied 9 years ago 2 Members · 2 Replies
  • Pane Talev
    13 December 2016 at 15:10
    Hi Gary,
    I cut engineers grade reflective supplied by Metalark with a smart knife.
    I only use smart knifes.
    Pane
    14 December 2016 at 11:54
    I cut more reflective (meterage of cut lines) than just about anything else, mostly using orafol films (not diamond grade types) which I think is classed as engineering grade? no probs at all on my D140R, usualy cut from 150 – 220g depending on the sharpness of the blade, I use the standard smart knives.
