Home Forums Software Discussions Corel Software Help with reducing objects in image
  • Help with reducing objects in image
    Posted by Mo Gillis-Coates on 26 May 2011 at 13:59
    Hi peeps, I’m trying to do a boundary on a vector file, but the file has 8000 objects in it and every time I try to put a boundary around the group X5 crashes.
    Is there any way I can reduce the amount of objects so I can put a cut line in around the image?
    BigMo
    Mo Gillis-Coates replied 14 years, 7 months ago 7 Members · 12 Replies
  • 12 Replies
  • David Rogers
    26 May 2011 at 14:15
    try not to select it all at once…worth a try.
  • Mo Gillis-Coates
    26 May 2011 at 14:18
    thats not possible, there are 8000 objects how am i going to find what object I want?
  • Chris Windebank
    26 May 2011 at 14:49
    arrange group then effects create boundary
  • Mo Gillis-Coates
    26 May 2011 at 14:50
    yeah I know how to do that but it’s crashing as there are so many objects in the image, but cheers anyway
  • Chris Windebank
    26 May 2011 at 14:56
    can you delete the inner objects
    or
    select all and hit weld might do it otherwise post and I can take a look later
  • Mo Gillis-Coates
    26 May 2011 at 14:58
    yeah, weld crashes it too
    26 May 2011 at 15:40
    well if u cant do the reduce node thing, i mean lots of manual editing… then you can convert the Bitmap and then trace… or use Magic Vector (?) website to trace it
  • Tim Painter
    26 May 2011 at 15:44
    Can you post the file Mo or is it massive?
  • Glenn Sharp
    26 May 2011 at 15:45
    Could try wireframe view and marquee select groups you know are safe to delete..
  • Mo Gillis-Coates
    26 May 2011 at 16:54
    its a vector image that I bought online lol… it’s massive but i can yousendit to anyone who wants a look
  • Dave Hudson
    30 May 2011 at 22:23
    Hi Mo,
    Possibly weld smaller sections at a time, saving as you go. 8000 objects? might still take a while…
    Otherwise, if its only an approximation to the original outline, colour everything black, export as jpg and let corel retrace as a single colour object.
  • Mo Gillis-Coates
    31 May 2011 at 07:44
    I solved it, I opened it in photo shop, saved it as a single layer in a pdf, imported into corel, traced the image, put the cut line in, deleted the image then put the original vector image inside the cut line…… Long winded but job done.
    Thanks everyone for you help
    BigMo
