Home › Forums › Printing Discussions › Sublimation Printing › help with printer
help with printer
Posted by Jack Hendrie on 29 September 2012 at 12:25new to the dyesub printing and looking for a cheap printer for tshirts can anyone assist 😛
Stafford Cox replied 13 years, 3 months ago 5 Members · 11 Replies -
Printers for dyesub are not too expensive……Epson and Ricoh are normally used.
Epsons use ink and the Ricoh a gel ink from what I have read.Main decision is A4, A3….or large format which is a different thing completely
I just replaced my dyesub printer ( died after more than 4 years almost daily use) with an Epson S22…..cost me £30 and I got £18.00 back for the original Epson ink carts……..I regard this printer as a cheap consumable item.
You cannot dyesub on just any t shirt……..has to be nylon specifically for dyesub….not that cheap and not the best feeling material.
john
so a normal epson stylus S22 can print these. Im used tojust cut my stuff but more and more people want photos.
its ok after some web surfing i found some ciss stuff think thats what i need for my epson 😎
thanks
The Epson printer is cheap……dye sub ink can be very expensive.
I have just started doing some repairs on Mimaki printers using Manoukian dye-sub inks. JV4’s and JV33’s seem to do a cracking job. Try speaking to Aaron at Sabur over Sheffield way, they’re really good guys.
Stafford
Stafford can you recommend any engineers who csn fix gerber envisions besides the obvious company?
Seem to be having a recurring problem which takes us down for a couple of days and then rights itself, very frustrating. -
I use Ricoh for dye sub stuff, previously had an Epson but ciss clogs very easily if not in constant use. The Ricoh doesn’t clogg so is ideal really just a bit more pricey.
If your looking to just do some cheap Tshirts why not use inkjet transfers? I do them quite a lot and no problems with washing.
Tom.
not going to lie i never knew ink jet was an option i will look into that now thanks.
Yes there are inkjet and laser options, Magic touch for laser transfers ant Jetcol ( I think?) for inkjet are a good place to start. Only difference between these and sublimation is you can sort of feel the transfers on the garment, but it’s never been a problem in my experience.
Tom.
quote Jason Davies:Stafford can you recommend any engineers who csn fix gerber envisions besides the obvious company?
Seem to be having a recurring problem which takes us down for a couple of days and then rights itself, very frustrating.No, sorry. I’ve been asked that a few times now but I’ve never met anybody who does them, apart from the obvious as you say.
