Home Forums Sign Making Discussions Neon, LED, Lighting Help with neon style / LED lighting on music stands
  • Help with neon style / LED lighting on music stands
    Posted by Billy Lawton on 4 March 2020 at 09:21
    Hi everyone,
    I’m looking for someone on here who can help me with creating an effect as shown in the pictures.
    I make music stands http://www.bigbandstands.com and normally create graphics as latex print or cut vinyl.
    We’ve had a request to produce an effect like the example attached. It looks like it’s a laser cut board mounted off the front of the stand, with a light behind that seems to go up at an unusual angle (tape?)
    Would love to work with someone on here to achieve this sort of service we can then offer!
    Thanks everybody
    Billy 🙂
    David McDonald replied 5 years, 8 months ago 3 Members · 4 Replies
  • David McDonald
    4 March 2020 at 13:40
    Hi Billy
    Why not have the whole front panel of the stand made from a clear or opal sheet of acrylic. For this design then flood coat the face with 100% opaque black vinyl with a cut out for the text to be illuminated, or print onto some light box back lit media or use self coloured transparent film for other coloured colours etc. Bond a cheap LED ceiling light behind the cut out – the 600mm square ones for use in suspended ceilings, then build this face into your stand structure. You could always try resin doming into the cut out in the black vinyl, or contour cut clear vinyl and resin dome this before laying it into the cut out. This slight bevel effect would add to the look and illumination effect. All cheap and readily achievable with you usual tooling, plotter and printer. You could wire the LED driver to a ‘kettle plug’ socket on the side/rear of the stand so users can plug it in – or skip the driver and install a suitable Ah capacity 12v/24v battery that the customer can remove and charge separately – don’t think it would need to be a full size car battery but something a bit more modest. You can also get 1200mm x 600mm, 300mm x 300mm, and 1200mm x 300mm LED light panels for bigger or smaller areas of illumination.
    Just an idea…..
  • Billy Lawton
    4 March 2020 at 13:46
    Wow Dave,
    What a brilliant idea. And such a superb reply!
    I’m going to put the kettle on and digest this!
    I’ll be in touch!
    Thank you
    Billy.
  • Martin Cole
    4 March 2020 at 16:30
    Excellent idea Dave.. ❗ I was making that in my mind while reading …
    problem solved I reckon Billy :smiles:
  • David McDonald
    5 March 2020 at 17:52
    Cheers Martin, hope you are keeping well and busy.
    Billy – if you make one this way then send me a photo.
