Home Forums Sign Making Discussions Vehicle Wrapping Help with md7 and matching Lam
  • Help with md7 and matching Lam
    Posted by Richard Urquhart on 20 February 2009 at 16:51
    Hi all
    I have some print work for a part wrap and normally laminate by hand wet !
    In over 14 months never had any problems and just wanted to ask, if I do the same for the above material could I be in trouble ???
    i.e is MD7 Lam much thinner and will i still be able to do this without a machine
    thanks Rich
    James Culpin replied 16 years, 7 months ago 4 Members · 9 Replies
  • 9 Replies
    20 February 2009 at 16:53
    Hi Rich
    I did my daughters car last year with md7 and matching laminate (wet and by hand same as you). The wrap was left on for about 10 months and there was no sign of any problems with it de-laminating
    20 February 2009 at 16:56
    wrap laminate was the last straw for us go buy a laminator and don’t look back.
  • Richard Urquhart
    That good enough for me, thanks mate
  • Richard Urquhart
    20 February 2009 at 17:00
    Chris if the baby printer gets replaced I will do as you say but for now and due to space its a no no
    thanks Rich
  • James Culpin
    21 February 2009 at 10:40
    Richard,
    The last company i worked for had a 1370 wide printer but could only laminate at 1150. Any wrap panels i was doing over that i did wet by hand. wasn’t ideal but it worked. as long as all the air and water comes out then it is fine. give it a little longer to settle/dry before you start applying though.
    Hope this helps
  • Richard Urquhart
    21 February 2009 at 10:42
    James thanks mate
    is the MD7 Laminate harder to work with i.e is it thin?
  • James Culpin
    21 February 2009 at 10:58
    About the same as most over lams for this kind of application. Depending on size i was laminating i would favor the hinge method with an over sized piece of lam that i knew could be trimmed on the edges should i get a little stretch when holding it taught (normally did single handed)
    The other thing to consider is see if you can find a company near by that do have laminator. At said company i use to work for, if we had a large amount to do then used to take to local exhibition company.
    take our prints and laminate and they do it for a trade price. We would help them out from time to time too.
    Hope this helps. None of the above are a sub for having laminator that suits your prints but i understand the space problem.
    Best of luck with it!
  • Richard Urquhart
    21 February 2009 at 11:04
    Normally get away with it fine, 3 meter is about max but have got it down to a fine art, was just worried the lam would be really really thin, thanks for your help.
    Rich 😀 😀
  • James Culpin
    21 February 2009 at 15:33
    I have used thinner lams. MD7 lam is, as i said about average given the application. I have every confidence you’ll be fine.
