Home Forums Vinyl Cutter Discussions Summa Cutters Help with increasing cutpasses and doing a tracktest
  • Help with increasing cutpasses and doing a tracktest
    Posted by Phillip Patterson on 6 June 2011 at 12:48
    Hi all,
    I was wondering if anyone has winplot or summa cutter tools and know of how to increase cutpasses and do a tracktest. I have seen it done on one of the you tube videos so know that it can be done.
    Hope you can help.
    thank you
    Phillip Patterson replied 14 years, 7 months ago 4 Members · 7 Replies
  • 7 Replies
    6 June 2011 at 13:30
    You can adjust the knife pressure and carry out a test cut using your machines (summa?) local panel if that’s what you mean?
  • Phillip Patterson
    6 June 2011 at 20:19
    no phill i can do that. what i want to do is find a way of adding another cut pass on an artwork. so for example, the letter A with 2 cutpasses will cut twice. basic on the rolands but not on the summas.
    6 June 2011 at 21:03
    you could tell it to return to start and send the file again.
    6 June 2011 at 21:16
    Surely all you need do is copy the artwork and paste it directly on top of the original?
    6 June 2011 at 21:24
    yes phill but i forget to remove it and wonder why it cuts twice next time.
  • Glenn Sharp
    I agree with Phil….just duplicate the artwork on top of the original and make sure both copies are sent through together
    I’ve got to ask why though ??
  • Phillip Patterson
    6 June 2011 at 21:52
    thanks ever so much for your replies as this has really been bugging me!!!
    for my roland, in versaworks this is just a standard option, i think on the printer options too. I was a little disappointed when i could’nt find it on my summa as i would expect a better standard and more comprehensive options as it is a good piece of kit and secondly its a standalone cutter.
    i’m hopeing to cut thick materials such as card, reflectivs and sandblast so its good to be able to pass twice, rather then have too much pressure and cut once.
