Home Forums Vinyl Cutter Discussions General Cutter topics help with cable from pc to cutter
  • help with cable from pc to cutter
    Posted by andrew lamb on 19 January 2006 at 21:30
    can anyone please help i need the cable that comes from my pc to the cutter the cutter is a graphtec pro fc5 100-130 on the rear there are three connectors
    1/ RS-232c (this has the cable that connected the machine to a mac)
    2/ usb
    3/ parallel
    went to PC world and the guy told me i needed special cables and connections
    I’m sure someone on this vast site uses a graphtec on there home PC.
    4/ what would the best set up be regarding the software
    thanks in advance
    andy
    TheDecalMan replied 19 years, 11 months ago 5 Members · 6 Replies
    19 January 2006 at 21:35
    Like I said andrew, give graphtec a call, they will pop a cable in the post for you.
  • Frank Droog
    19 January 2006 at 21:41
    If you want to go serial, you need a plain jane NULL MODEM cable.
    Make sure it is not a MODEM cable AKA a straight through cable AKA an extension cable. It must be a NULL MODEM cable.
    You probaly want a 9 pin female to either a 9 or 25 pin Male Null Modem cable. The 9 pin female plugs into the serial port on the computer. You need to check if the plotter has a 9 or 25 pin serial port.
    Parralel and USB should be standard off the shelf cables.
    Only option is length.
  • andrew lamb
    19 January 2006 at 21:43
    peter what is the cable that i need is it for usb/parallel/rs-232c are graphtec the only folk that do it or can i get it from maplin etc?
    do you have a contact no for graphtec ta
    19 January 2006 at 21:51
    Like frank said or Graphtec
    http://www.graphtecgb.com/Contact.html
    (0)1978 666700
  • Neil Roberts – Graphtec
    20 January 2006 at 09:18
    Hi Andrew,
    Both the USB and parallel interfaces use standard cables. RS-232 is slightly different, this needs to be wired in a certain way. All Graphtec RS-232 cables have “Graphtec” stamped on the ends, if you get one of these it will work.
  • TheDecalMan
    22 January 2006 at 01:13
    Why not Just buy a Standard USB Cable ?
    The Wiring on these cables are “Universal” so No Problems !
    If its any help I use a Graphtec and that has a USB “B” Type Socket – I got my cable from PC World No Problem.
    Most Cutters i have Come across Use a “A” to “B” Type Cable.
    Just Check you Have a Spare USB Socket on the PC
    Hope this helps you get up and running !
