Home Forums Software Discussions Corel Software help with background removal on x3
  • help with background removal on x3
    Posted by Craig Newton on 15 September 2009 at 18:29
    good evening, is there a remove background button on x3? ive an image i want to use but its got a solid black background, cheers guys
    craig
    Alan Drury replied 16 years, 2 months ago 4 Members · 4 Replies
  • Glenn Sharp
    15 September 2009 at 18:34
    Craig,
    In Corel Photo Paint there is the Cutout feature……..It’s far from a one button operation but it works quite well….
    Double clicking the bitmap in corel draw should automatically launch paint then go to Image and choose Cutout
  • Craig Newton
    15 September 2009 at 19:42
    spot on i always forget about photo paint, cheers buddy
  • Andrew Blackett
    16 September 2009 at 06:36
    Or theres bitmap colour mask in corel draw, launch it from the bitmap menu then click colour mask. In the flyout click the eyedropper tool (the one in the bitmap colour mask window not the normal toolbar)
    Click on the colour you want to remove (i.e. the background) click on apply, then just move the tolerance bar up and down and press apply again until you reach a satisfactory result.
    Andy
    16 September 2009 at 07:51
    Depends a bit on the image but I sometimes trace and slide the detail down untill I have just 1 shape and then I powerclip the bit map into that shape, I would then have a bitmap to print and a vector line to cut if contour cutting.
    Alan D
