Home Forums Printing Discussions Mimaki Printers Help with Alignment on a Rockhopper 3
  • Help with Alignment on a Rockhopper 3
    Posted by Conny on 18 July 2009 at 10:16
    Hello!
    I’ve just bought myself a Mutoh Rockhopper 3 and I have started to experience problems with the alignment. Is there anyone that has any tips for how I can get it to align again, I’ve tried to align it with the testprints but it doesn’t seem to help, what can have caused this problem?
    I also want to ask if anyone know where I can get image configurations for this printer with the Wasatch RIP since the company that i bought the Wasatch from doesn’t seem to have it, or seem to have a interest in helping me find some.
    Thank you.
    An image of the problem:
    As you can see the yellow head is way off.
    Eric North replied 16 years, 4 months ago 1 Member · 1 Reply
  • 1 Reply
  • Eric North
    31 August 2009 at 22:40
    I have recently acquired a second hand "Rocky" III and have been learning up on it.
    If you dont have the Mutoh manual goto
    http://www.mutoh.be/Mutoh-Europe-Member … .aspx/3445
    join for free and get it.
    It wont solve your problem but helps !.
    I am only slightly initiated in servicing but I do know that holding down the f2,f4 and enter key while pressing power gets us into the service module.
    Back to the problem. There are four heads each with two colours in them.
    The heads are adjustable this will take you further than normal operator maintenance so beware. The first and last heads have black and yellow in them if you are running 2 x cmyk carts.
    Assuming this to be the case then either of these heads could be badly positioned.
    If you do a test print nozzle check then the first yellow printed on the right is the head on the right and the second yellow is the head on the left.
    black should be out of position as well if its head alignment.
    If you have a maintenance agreement dont do this !.
    goto head unlock and this will allow you to move the head over to the left where you can look at it.
    assuming you work out how to take the head cover off then comparison should help here. one head may not be seated correctly.
    there are two screws adjusting each head for position.
    This where trial and error takes over unless you can decipher the service mode. dont damage the head or the belt cables please !.
    dont leave the head uncapped for more than an hour or so.
    hope this gets you some where.
