help with a basic problem for a beginner
Just found this board after google searching, trying to find some help or answers.
After reading many of the posts, I have noticed that there are several people here that seem to have a less than favorable opinion of those of us that have purchased the "cheaper" hobbyist’s type of plotter, which is fine, though I do ask that unless you are going to offer some helpful advice, I would prefer you not to reply.
I have no intention of going into commercial sign making and taking business away from others. I purchased a plotter/program more as a personal interest or hobby. Yes I build & prepare race cars, which is what I will be using this system for, although most major graphics and lettering I will still source from one of my local sign suppliers.I purchased a new Creation PCut 630 which came with ArtCut 2002 software. The operating manual for both a very ordinary. I’m kind of learning as I go, but flying blind. Pretty much just "clicking" on different things trying to make what I want, happen.
I have been trying to cut a basic sign, length ways down the vinyl, approx. 1800mm long. I have managed to cut the text successfully, BUT, it seems to spool through about 2M of vinyl first, then appears to register where the end of the cut will be, before spooling through to the other end of the text and beginning cutting. This means I end up with 2M of unused vinyl at the start of the cut text, which I assume is not correct as I would always need to be using a piece of vinyl which is 2M longer than actually required or else it will spool off the drive rollers.
Before cutting, I have been taking the plotter "off-line" and locating the blade manually (using the buttons) near the end of the vinyl, pushing the "0" co-ordinates button followed by the reset button which then puts the plotter back "on-line", which is what the operating manual seems to say.
I have gone to the "vinyl page setup" screen but can’t really see anything there that sounds like what I need to change.
I assume that I have something set incorrectly, but am in need of some help.Thankyou
Warrenmod-edit
