Home › Forums › Printing Discussions › Roland Printers › HELP…versacamm still in cleaning mode !
Posted by Cheryl Tissington on 7 May 2006 at 16:53Hi,
can anyone help please.Switched on my versacamm sp300 and it went into cleaning mode !
30 mins later its still showing the same. Can’t do anything with it !
Is this right ?
Cheryl 😕
Cheryl Tissington replied 19 years, 8 months ago 4 Members · 6 Replies -
Did you turn it back off and on? Shut off main power? Is your cleaning button stuck?
-Marek -
Cheryl
is it saying time for Maintenance? or is it literally stuck in a cleaning cycle?
If it’s saying time for maintenance , you can bypass this by pressing Enter.
but i would do a cleaning cycle on it. hold down the cleaning button while turning it on and that will go throughteh process for you.
if it’s stuck i’m not sure what to do? poss turn it off at the plug for 30 secs and reboot it…….
Hi Guys,
thanks for your help.I don’t know what happened. I just turned it on and it showed cleaning…. in the panel. I thought 30 mins might be a wee bit too long !!!!
It wouldn’t respond to me pressing anything so in the end I turned it off by the button on the side.
I’ve waited a while and switched back on again.
It seems to be ok…..its measured the media and is ready to go. 🙄
Going to play again 😮
Thanks again
Cheryl 😀 -
Mine has never done that, but I have gotten a random error message before. I called my tech and they just said turn it off, then back on and see what happens. It always clears out doing that.
-Marek -
yeh i had a similar error of some sort a while back and switching it off at the mains worked…glad you got it sorted cheryl and happy printing…..bet you havent been away from your new toy all weekend 😉
Hi Nik
yes, its fun !
I got a bit carried away and printed loads of different pictures on lots of different materials earlier………now I don’t know what to do with them all 😮
Its a bit of a waste, but I need to play around and learn as much as possible before I have to produce something important.
Its a bit scary when its in sleep mode but keeps waking up…… It like its alive ! :yikes:
Anyway, I’m sure I’ll get the hang of it. 😀
Cheryl 😀
