Home Forums Vinyl Cutter Discussions General Cutter topics Help required, what am I doing wrong?
  • Help required, what am I doing wrong?
    Posted by Steve Goddard on 10 August 2009 at 08:49
    I’ve noticed that when I’m either cutting text or shapes my Jaguar II cutter always seems to leave a small part on certain letters uncut, about half a millimeter or so. On the bigger stuff it’s not too bad but I’ve got a job in at the minute that requires me to cut 8mm text and as you can well imagine it’s making weeding a nightmare.
    Can anyone advise me as to what I am doing wrong? I’ve checked the blade on the cutter and that all seems to be fine, the only thing I can think of is there might be something in the settings that I’ve missed
    Steve Goddard replied 16 years, 3 months ago 3 Members · 4 Replies
    10 August 2009 at 08:57
    blade offset?
    is it rounding corners too? if it is then you need to increase the blade offset slightly,
  • Steve Goddard
    10 August 2009 at 09:22
    Yeah it is mate, I think you may have it spot on there, how do I adjust the blade offset? I have to admit that’s not one of the options I’ve discovered yet
  • Nigel Pugh
    10 August 2009 at 10:54
    Steve take the jag offline, press the offset button to change its value, press enter to confirm new setting and then put the Jag back online.
    Nigel
  • Steve Goddard
    10 August 2009 at 14:25
    nice one, cheers Nigel, I’ll have a go at that when I get home
