Home Forums Sign Making Discussions File Swapping help required
  • help required
    Posted by Martin Parker on 17 February 2008 at 22:38
    hi i was wondering if someone can tell me how to remove the word custom from this in adobe illustrator 10 as i cant seem to figure it out as i am new to illustrator
    Martin Parker replied 17 years, 10 months ago 2 Members · 3 Replies
  • Howard Marshall
    17 February 2008 at 22:58
    If its a vector file you are using in Illustrator then you should be able to go to Object – Compound Path – Release, then just select the bits you want to delete with the cursor. Hope this helps.
  • Howard Marshall
    17 February 2008 at 23:02
    Try this.
  • Martin Parker
    17 February 2008 at 23:41
    thanks howard much appreciated
