Home › Forums › Sign Making Discussions › Vehicle Wrapping › Help Removing side strips off renault traffic 62 reg
Posted by Dean Poulter on 17 January 2013 at 16:33Please can someone advise me on how the side plastic strips are removed on a 62reg renault traffic
Cheers Dean
Stephen Ingham replied 12 years, 10 months ago 4 Members · 6 Replies -
They pull off but the clips break easily and you will probably need to buy new ones.
We have even warmed these up to try and avoid the clips shattering but you will alway ruin some, just grab some from main dealer and replace them where ness.
Thanks for your help. Sounds like its going to be fun!!
So come on and place your bets How many will i break???????
Will post actual amount in the morning!!
REgards Dean
any advances on 20 !!!!!!!!!!!!
i was hoping you was going to say 2 or 3 !!!!! Wishfull thinking hey
if it is the same as the vauxhall vivaro then they slide off without breaking…
if i recall the front door ones slide backwards and the back ones slide forwards, it may be the other way around.
what i usually do is do one side and learn before doing the other side, then any clips that break can be sourced from the unbroken side, if that makes sense?Hope that helps
