Home › Forums › Sign Making Discussions › General Sign Topics › HELP!!! Reflective vinyl
Posted by Alison Falzon on 18 August 2006 at 15:44Has anyone ever stuck reflective vinyl onto Correx? In fact any vinyl onto correx?
Does it go on okay?
I’ve been asked to price up lots of boards for an estate agent, and they are adamant that they want part of it to be reflective. I don’t know much about screenprinting, which is how most estate agents boards are done, and as far as I’m aware you can’t screenprint reflective, so vinyl could be the only option – unless someone kindly can advise me otherwise!!
ANY advice at all on this would be greatly appreciated!
Many thanks
Ali
Peter Normington replied 19 years, 4 months ago 12 Members · 20 Replies -
Ali
Yes you can apply reflective vinyl (or ordinary vinyl) to correx.
I would lay it dry as correx is quite forgiving and most vinyls can be laid
down in that way.However, if you are laying down a solid background all over the sheet of correx then I would lay it wet. Hope that helpsRegards
Alan -
Yes as Alan said but if you’re doing large quantities what about screen print and then overlay the reflective bit as required.
Yes I would have the corosigns screen printed and then lay on the reflective.
It’s thick to cut.
Do not apply wet.
It sticks like crap to a blanket, so be careful.
You’ll do just fine.
love….Jill -
Thanks guys. I’ve used reflective before, but only on vans. I think I have to price it up for all options – i.e part screen print / all vinyl etc.
By the term "loads of boards", the actual figure is 400. (200 double sided), so he may have to wait a year or so before they’re finished! I’ll have to draught in the whole family to help me out!
On that note, does this change anyone’s opinion on the best way to do them?
Buy an Eze-Taper! :lol1:
Seriously though, you will get air bubbles down the grooves unless you are very careful, also if you lay dry & wonky you may tear the rfl. when lifting. I’d do it wet. -
Alison, I digi print directly to reflective all the time, so I don’t know why you can’t screen print it. Never heard that before.
I’d be screen printing 200 d/s boards definately. Its going to be double handling anyway, if you have to add the reflective too.
Vinyl will be an expensive option, and real estates don’t like paying too much at the best of times…
If you use 3M 180 reflective it is removeable and repositionalable, bit more expensive, but you’ll have less stuff ups which save you money in the long term.
Alison
3M’s used to do a screen print ink which is basically the reflective glass beads in a suspension fluid which you can screen print but cant remember the name or how bright it was.
Sorry I can’t be more specific but it might be worth contacting them to find out.
Colin
Sorry…..slight misunderstanding – I know very little about screenprinting, because I don’t do it myself – if they were to be screenprinted, I would have to sub it to someone else, but I just didn’t think reflective could be done by screenprinting
To do 400 boards in vinyl would take forever! And probably not be much quicker by getting part screened, and the rest overlayed with the reflective (you’ll know what I mean if you see the design!).
I’ve been at a loss really of the best way to go about it, and the possible options. The things that make it not straightforward (in my opinion) are the fact that they are not straight-edged, and that a substantial amount is to be in reflective.
In vinyl, each board takes a set amount of time, and the time spent doing each one is no quicker whether there’s 10 boards or 1000 (if you know what I mean). So part of me is left pondering whether the boards are actually do-able at all for a cost that isn’t ridiculous, or if the design should be changed completely, with the customer sweetly encouraged against the reflective! I already did tell them that reflective is much dearer than standard colours, but they seem quite adamant regardless!
…..the dilemma continues…… -
Alison the way to do this job would be to cover both sides in reflective, screen print the rest of the design and then die-cut to shape. I would say you would not get much change out of £15:00 each!!!!
Alison,
(mod-edit) The only problem being the boards would need to be laminated as the glass beads that give the reflectivity are exposed.
Robert
Sorry – Didn’t think it would be allowed – hope no offence has been taken. I was only trying to help.
quote :I would say you would not get much change out of £15:00 each!!!!
My thoughts exactly. It seems like a hell of a lot for estate agent boards!!
Allison, give them an estimated price £30 each, which is about what you would need to charge to give you a fair profit? if they are still up for it then you can figure out how to do it.
PS do not apply reflective wet, for some reason it will not stay put,
£30 each – do you mean £30 per board (2 boards to each sign), or £30 for the 2?
Alison,
whatever the the cost to you for the reflective, correx, vinyl/print, then cutting to shape, there is quite a lot involved, just make sure that your client wants to pay for something different, before doing all the hardwork, estate agents dont usually want to pay more than a few quid for a board. A few companies specialise in the boards, and putting them up etc. so your customer may think reflective is only a few pence more.
You may be trying to provide something that is not viable to the customer as they have no idea of the work and materials invoved, give them a price guide and see if they are still interested,Peter
aaargh!
Right then…….we are now going to ditch the reflective, and have silver instead. Is it possible to screenprint silver?
If it is, then correct me if I’m wrong but that would probably be the best and most economical option??! -
hi alison 😀
yes you can screenprint silver onto fluted boards, as i have done in the past 😀 bet your glad they ditched the reflective eh!! 😉
I did try my best to discourage them (not to much avail though). The main influence that helped though was someone from the council telling them that they have to be careful where they put them as the reflective may breach planning regs!!
Normally the best way to discourage them is
to tell them the price 😀 -
I tried that before – told them the price of reflective is TEN times dearer than the cost of normal vinyl!!
So allison, they want to pay for a unique product, give them the price, and if they accept, sod the council and make yourself a few quid.
