Home › Forums › Software Discussions › Adobe Software › Help putting contour line around logo
Posted by Dean Poulter on 17 January 2012 at 13:22Can someone please help me put a contour cut around a logo i have but the problem is it is a big file
Dean Poulter replied 13 years, 10 months ago 6 Members · 12 Replies -
Try a search Dean, has been talked about before with adobe products but I don’t really use them so can’t help.
stick up a low res jpeg to see what the problem is please
The problem it is a vector and it is made up of thousands of small parts and is too big even in a jpeg format
If using Illustrator;
copy and past in front (so you have an exact duplicate), hide the selection to make it easier and only have one copy on the artboard
select all
expand stroke
select all
fill all with any colour
merge
select all and fill again with any colour
merge again
remove fill and you should be left with just the stroke which you can expand path if you want it slightly bigger than the image. -
Still struggling please find a link to download the file
all help will be much appreciated
http://www.4shared.com/file/-Ax3lc0s/Wheel.html
Thanks Dean
sorry I tried but there is something wrong with that file and it opens weirdly
sorry forgot to add, from what I could see in the preview if you follow my instructions above it should work fine, you might just have to leave the expanding part out if it doesn’t have any strokes.
can`t you digitize around the shape and then convert that into a cut line… sorry haven`t seen the shae.
sorry for the delayed reply, thankyou all for the help and it worked spot on thanks once again
Dean
