Home Forums Printing Discussions General Printing Topics Help Printing Pop Up Banner Panels
  • Help Printing Pop Up Banner Panels
    Posted by David Hammond on 4 May 2012 at 08:24
    I’ve never done a Pop Up Banner but looks like I may have a few orders in for them over the next few weeks.
    I’ve for a supplier for the stands, and the dimensions for each panel.
    What is the best way to produce the artwork and print the artwork?
    Design it the full size of the stand, then in versaworks tile the image?
    Put each panel on a separate art board in illustrator?
    David Hammond replied 13 years, 6 months ago 5 Members · 9 Replies
  • 9 Replies
  • David Rogers
    4 May 2012 at 08:54
    TBH I usually find buying them in pre-printed for £70 a pair works for me…
    ZERO hassle.
    4 May 2012 at 10:47
    Same here, I buy them from Print United, they are only up the road from me so I pick them up.
    I just make a rectangle 2000mm X 850mm (standard size) populate it with the graphics and then publish to pdf from Corel or print to CutePDF with crop marks. Cute produces smaller file sizes but publish is better if design has transparencies or drop shadows over vector objects.
    Alan D
    4 May 2012 at 10:49
    I’m ok doing the Roll Up banners @ 850×2000 mm
    This is one of the big exhibition pop up displays, 3×3 size.
    Not sure how to tile the image to get perfect alignment?
  • Andrew Blackett
    4 May 2012 at 17:53
    Hi David,
    Set your page size as quarter size the whole stand (i.e. the total width of the five drops)
    Design as normal, publish with a 5mm bleed all round, no crops or file info.
    In versaworks start by expanding it to 400%. Now under clip and tile you will create the drops. If its a 5 drop stand (3 middle and 2 ends) you’ll need;
    7 horizontal tiles
    3 vertical
    2 of the horizontal will be the bleed left and right and 2 of the vertical will be bleed top and bottom. The "bleed" tiles will be 20mm width/height (400% at 5mm original size)
    I find it easier to tell versaworks how many tiles I want then use the "manual tiling" setting. Start top left and key the width and drop of the first panel;
    location 1 – column 1 – 20mm wide x 20mm high (bleed size)
    location 2 – column 1 – 20mm wide x "pop up height"
    location 3 – column 1 – 20mm wide x 20mm high (bleed size)
    then;
    location 1 – column 2 – "pop up panel width" x 20mm high
    location 2 – column 2 – "pop up panel width" x "pop up height"
    location 3 – column 2 – "pop up panel width" x 20mm high
    Column 3,4,5,6 will be the same as column 2
    Column 7 will be the same as column 1 (maybe give or take a fraction of a millimeter)
    Once you’ve keyed all these, right click on all the bleed areas to disable the printing of them (you dont want a load of 20mm strips!) You need to set an overlap on all corners of say 3mm (this will be your actual trimming bleed)
    If I remember rightly it will automatically add the crop marks, if not just select trim marks. Centre the "tiles" on your media and away you go!
    Dont know if you’ve already sorted it but I’d recommend the solvent pop up media from paper graphics. Prints beautifully and dries quickly, I just use our standard vinyl profile and temperatures as normal.
    Hope this helps, shout if I can help further though David – best of luck.
    NB. Dont delete the job until you’ve successfully printed, laminated and trimmed (and fitted to the stands) just in case you need to print one drop again!
    Andy
    4 May 2012 at 18:18
    Awesome. Thanks for that.
    I’ve not VW infront of me, but will take a look next week and play with it on a smaller scale first.
    I’m hoping I get the job now!
  • Andrew Blackett
    5 May 2012 at 07:36
    No problem – if you do a smaller one keep in mind that the smallest width tile that versaworks will create is 9.75mm ish – that annoyed me for ages!!
    Why not just publish a blank page at the right size and familiarise yourself with it that way?
    Andy
    5 May 2012 at 16:56
    Yeah I’ll try a full size blank one, but want to see how the tiling works.
    I did a big sign the other week I tiled and wasn’t 100% on what I was doing.
    7 May 2012 at 14:58
    think we print 800×2000, not 850×2000
    8 May 2012 at 08:00
    I stock the 850 wide banner stands rather than the 800.
    Just a personal preference.
