help please on layering vinyls?
I recently made up some logos for a friends van. I wanted to put as much of them together on the bench as possible but couldn’t seem to get my organisation right!
(Image is in file swapping forum if you would like to look!)
The main problem was that I cut all the colour layers together, but then found that when I came to put them all together the different layers needed to be split up. For example the base layer is yellow in the main square area, but the yellow is on the top of the lower section.
Also, the when I was applying the blue layer onto the background yellow layer I had no way to get the blue text to stick to the backing paper of the yellow layer, as of course the application tape is much stickier than the vinyl’s adhesion to the backing.
I had a nightmare with the first logo, and ended up putting the others together as much as I could on the bench and then finished the layers when I actually had the base layers on the vehicle. It took bloody ages to apply what amounted to 4 medium sized graphics, due to the number of layers and all the alignment required.
Any genius methods for a job like this?
